harmonic balacer Sh*t itself HELP!! PICS.
#31
I always use a new bolt.. Yea the stocker might work or it might snap when your torquing it down or just come loose. I would rather be safe then sorry cuz I really not a fan of pulling engines out
#33
...not to mention that you've already had a problem with the balancer coming loose, and it looks like you dodged a bullet as the crank looks OK in the pics. The bolt looks fine in the pics also, but why take the chance in this case especially?
#36
I would NEVER reuse the stock TTY bolt, and I would never use locktite on it. Install the pulley with the special tool/torch/longer bolt, then tighten the pulley with the old bolt, then torque down the new bolt and go an additional 110* or however many the manual calls for. I use a 4 foot cheater pipe.
But there are plenty of other things that I do half-***, so I won't preach too much
#38
well i'm gonna buy a new bolt a less than $5 bucks its a no brainer, i'm install the stock pulley saturday. so what is the right way to install this thing. personally i use the install tool that presses it in and then tighten down the bolt jst w/ my HEman strength...
#40
I believe that the factory procedure is to put the old bolt in and tighten it to 240 ft/lb, then remove, install the new bolt and tighten to 37 ft/lb, then turn it another 140* to tighten and stretch the bolt. IIRC, the last time I did mine I couldn't get the whole 140* but the bolt was effin tight and hasn't given me a problem with over 40k on it
