harmonic balacer Sh*t itself HELP!! PICS.
Old Feb 16, 2011 | 04:00 PM
  #21
iamkeniff's Avatar
i never reused my stock crank bolt on ANY cam swap ive done on my trucks, Skoal Bandit, Skipperdaddy, i put a UD crank pulley on 1sik02 but he bought a new GM crank bolt and i put some red loc-tite on it and put my 250lbs azz on it
Old Feb 16, 2011 | 05:38 PM
  #22
dirt track racer 81's Avatar
Im going on 14-15 times on my original stock 5.3 crank bolt with no problems. Use a tool to press the balancer on and use an impact to tighten the bolt. Never had a problem.. Just sayin for the guys that say you MUST change your bolt or disaster will happen. Yes its tty but if youve looked at a used head bolt and the threads are stretched, if you look at a used balancer bolt they are not stretched and all the threads look exactly the same.
Old Feb 16, 2011 | 08:17 PM
  #23
Country Boy's Avatar
Senior Member
You sir, have much bigger ***** than I. Ive read many times where people are breaking the crank bolt from reusing it. Since youre using a pulley installer, your not cranking that stock bolt to 240 ft lbs every time you use it so telling people to reuse it "just because you've done it" is bad. Most wont be using a pulley installer.
Old Feb 16, 2011 | 08:27 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I reused my bolt 4 or 5 times with no problem. I got a 120mm long bolt to get the pulley sucked on most of the way then swap it for the stocker and snugged it down the rest of the way.
Old Feb 16, 2011 | 08:42 PM
  #25
00ChevyScott's Avatar
Wearin' da big hat
Nope, the smart people without a pulley installer use a torch
Old Feb 16, 2011 | 08:59 PM
  #26
I was just stating what I have done and done to another 20+ vehicles that I have done cam swaps on. I never once told any one to do it. I turn my motor 7200 and I'm not the slightest bit worried about it. The people that have issues destroying their bolts are trying to pull the pulley back on to the crank. That is just asking for disaster. The cost of any tool that presses on the pulley greatly over weighs the possible outcome if you used the stock bolt to pull it on and destroy a crankshaft.
Old Feb 16, 2011 | 09:18 PM
  #27
Phantom's Avatar
11 Second Club
Not bragging, but I've never bought a crank pulley bolt...We've had my pulley off and back on ATLEAST 15times, same bolt...We always are kinda spur of the moment working on **** so thats probably the reason we have always reused them. But, we have reused them and NEVER had an issue. If you're planning ahead, go ahead and get a new one. I think they're $4. If you forget to get one, don't worry about it and just re use it, you'll be fine
Old Feb 16, 2011 | 11:17 PM
  #28
TXsilverado's Avatar
it's $3! cheap asses lol. you can do 100 random women without a condom and never catch a STD. then you get to #101 and catch gona-sifa-herpa-laids.
or like my dad says. "if you keep pushing that button eventually your number is coming"
Old Feb 16, 2011 | 11:27 PM
  #29
Phantom's Avatar
11 Second Club
I'm a firm believer that if I haven't caught anything yet, I'm pretty much invincible
You're right man. Its only $3. If you're planning ahead, put a bolt on your list of things to buy. If you forget, its not the end of the world, get it next time
Old Feb 16, 2011 | 11:39 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
I rewore my underwear 15 times and never smelled like ***, you'll be fine I'm trying to save the $.25 that it will cost me in water and soap to wash them.
