got a question on a 2000 tahoes with a 5.3l
Old May 12, 2008 | 08:57 AM
transamsam98's Avatar
Default got a question on a 2000 tahoes with a 5.3l
is it an ls derived motor and is it worth modifying at all? I am wondering because my friend has a wrecked one
Old May 12, 2008 | 09:30 AM
LS6_Silverado's Avatar
Yes, 5.3 is a ls based motor. Is it worth modifying? That all depends on what type of power you want and what you will be putting the motor in. Ive seen S-10's with 5.3's in them running high 13's. The one thing i dont like about the 5.3 though is how it has dished pistons only thing dished pistons are good for is f/i.
Old May 12, 2008 | 09:39 AM
well I am picking up a 77 corvette today more than likely and wanted to do a swap how easily could i get say 450hp out of a 5.3? also do the same rules of modification that the 5.7's like do they apply to the 5.3?
Old May 12, 2008 | 09:41 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
You will need to go turbo/supercharge or pump a lot of nitrous to get those numbers from any of the stock engines.
Old May 12, 2008 | 09:51 AM
what kind of resulds have guys had from ported heads and a cam from these motors? whats the compression ratio that they have?
Old May 12, 2008 | 09:55 AM
dlt76028's Avatar
heres a n/a 5.3 that making 400hp to the wheels... https://www.performancetrucks.net/fo...d.php?t=411125
Old May 12, 2008 | 11:30 AM
00Silv4.8's Avatar
heads, cam and a bitchin tune can get good numbers. If you do that and F/I u'd be decent. Maybe look in to boring it out a little? and different pistons? u just have to have everything complement one another
5.3lSilverado
25
Aug 29, 2016 12:48 AM
5.3Caprice
Nov 7, 2015 08:56 PM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
