Fuel pump question ASAP please
Old May 11, 2008 | 02:56 PM
Onetogofast's Avatar
Default Fuel pump question ASAP please
2005 silverado and newer with nonreturn fuel system. Where did you guys get your pumps. I bought one from texas speed and the guy I talked to said that just because the web page says to 04 it will work but now that I have the pump out it is not looking that way. What pump assembly are you guys running and where did you get it from?
Thanks
Ryan
Old May 11, 2008 | 03:08 PM
7845's Avatar
Banned
what seems to be different. return style or not shouldnt make one bit of difference when replacing the pump itself
Old May 11, 2008 | 04:26 PM
53RUSSELL's Avatar
Thanks
Ryan
Here is a link https://www.performancetrucks.net/fo...walbro+install
Old May 11, 2008 | 09:34 PM
Thats the thing I dont know if there is any diff or not. Never seen the pump of either one of them. The walbro is skinnier and shorter and my filter is in the tank, the rubber hose it comes with will not fit the fittings or anything but I thought about skipping it and just putting a inline filter. Im just lost, its diff than the one in my buddys t/a and i thought it would be the same
Old May 11, 2008 | 09:39 PM
7845's Avatar
Banned
it cant be much work to make it work. i havent seen a 04+ pump but seen Fbodys and its only minor fab to get it to work
Old May 11, 2008 | 09:51 PM
Originally Posted by 53RUSSELL
The pump assembly in that pic is diff, looks a lot smaller too, I am hoping that someone with a 05 or so will chim in.
Old May 12, 2008 | 01:21 AM
53RUSSELL's Avatar
I have the pump from texas speed and just cut the bottom of the bucket off and spliced the new pump in to the existing wires.
Old May 12, 2008 | 12:27 PM
What will cutting the bottom of the bucket off effect in a bad way? I have always kept a 1/4 tank in it since I bought it, so if loosing pick up would be the only thing I would be ok and might just do that.
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
slowlsx
Aug 13, 2015 08:28 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
