GMPP EFI Intake for L31 Engine
Old May 16, 2008 | 05:53 PM
Gary Z's Avatar
10 Second Club
Default GMPP EFI Intake for L31 Engine
I recently purchased a 2000 C3500 pickup with the 350 L31 engine. I am interested in replacing the weird intake manifold and injectors. I have searched here and am surprised to find no mention of the GMPP EFI intake manifold (Part Number 12498032) for SBC Vortec engines. I find old information about the “marine” intake but nothing about an apparently superior alternative. Why is this?
Attached Thumbnails GMPP EFI Intake for L31 Engine-gmpp-efi-intake-12498032.jpg
Old May 17, 2008 | 09:09 PM
Lextech's Avatar
Hey Gary,
Did you do a search for "Ramjet"? I have the Ramjet on my truck. It is NOT a straight forward install on our trucks. I am glad I used it, but it was a lot of work to get it installed. You can check on PacificP.com also.
Jeff
Old May 17, 2008 | 10:43 PM
dirt track racer 81's Avatar
you would need a different computer to run with that intake with seperate injectors
Old May 18, 2008 | 12:14 AM
Keith's Avatar
Not sure about that.
Old May 18, 2008 | 12:33 AM
now that i think about that i know the 454s have 8 injectors but the 350s are they still like the 97-98s? if they are like the 97-98s it will need somethin different to run the 8 injectors versus the one main injector on the old ones
Old May 18, 2008 | 01:25 AM
southern_chevy's Avatar
if you are looking into that intake and performance I would look into the 411 PCM swap it is pretty easy and would make you tuning options better.
Old May 18, 2008 | 06:24 PM
Gary Z's Avatar
10 Second Club
Thanks for the help guys. I’m finding more information now. I don’t think I'll need to replace my 16263494 PCM. I already have HPTuners software that can read the PCM. I just need a license upgrade in order to write. Converting to newer type injectors shouldn’t present any major electrical difficulties. Technically, the L31 already has multi-port, sequential fuel injection. I just don’t like the unusual poppet-type injectors with their plumbing inside the manifold. I haven’t yet decided to change anything. I'm just learning and exploring my options.
Old May 20, 2008 | 10:06 PM
Truckshop's Avatar
it is not necessary to replace the pcm for the truck to run but it will not spin past 5800 rpm's. so depending on your cam selection that could present a problem.
Old May 21, 2008 | 12:33 AM
Gary Z's Avatar
10 Second Club
Good point - thanks.
-Gary
ARC
57
Feb 21, 2022 10:54 AM
shawn96gmc
May 17, 2016 04:15 PM
USMCvet0311
Sep 30, 2015 10:34 AM
Nimoryan
Jul 5, 2015 03:50 PM
