GM 5.3 Yukon, is this custom grind OK?
Old Jul 13, 2016 | 10:15 AM
tgui's Avatar
Default GM 5.3 Yukon, is this custom grind OK?
I talked to Comp Cams and got their suggestion on a cam for my application. What I sent them.
- 02 Yukon
- 5000+ lbs
- 3200 stalled 4l80e
- needs to tow a little
- needs to support a turbo in the future, not too much overlap
Here are the specs suggested. What do you all think?
I'll get springs, hardened rods... what else?
Old Jul 13, 2016 | 10:22 AM
madmann26's Avatar
It looks fine.
-8 degrees of overlap.
How it "feels" is going to depend on how loose or tight the converter is.
Old Jul 13, 2016 | 10:42 AM
tgui's Avatar
Originally Posted by madmann26
It looks fine.
Oh.. shes a loose girl alright
I'm used to it.
Old Jul 13, 2016 | 10:58 AM
madmann26's Avatar
I'm used to it.
It'll be peppy. Does that help? lol.
When I ran my Comp LSR265 grind, (219/227 I think), it was plenty peppy off-idle.
Old Jul 13, 2016 | 11:01 AM
tgui's Avatar
Good to know! A this point ANYTHING will be better than my stock engine! 285 hp, suck....
Old Jul 18, 2016 | 09:08 AM
Slow05CC's Avatar
Avery@texas-speed.com
Seems fine. you will need springs! Singles will be fine, and I'd look for a .625" lift. Hardened pushrods are a must! 7.4s would most likely work, but I would recommend getting a pushrod length checker and making sure. Also, get a really good trans cooler! like a tru cool 40,000.
Old Jul 18, 2016 | 09:43 AM
03sierraslt's Avatar
It pull good at wide open but when towing with the converter locked on the highway it's gonna be a dog. For a 5.3 that's gonna tow a 222/222 .596/.596 115+4 is a bit much. Turbos don't need a lot of duration so personally I would move down into the 218 range.
Old Jul 18, 2016 | 09:57 AM
tgui's Avatar
I'll get the length checker!
Covered on the cooler. Tru Cool 40k!
Old Jul 18, 2016 | 09:58 AM
tgui's Avatar
Good point on the duration. I'll see if they can do 218/218 596/.596 115+4 then.
Chevyssr1997
Mar 2, 2016 11:46 AM
blown4now
Aug 7, 2002 10:35 PM
bdubb
13
May 30, 2002 08:00 AM
bdubb
Apr 29, 2002 09:52 PM
Maxmumboom
16
Apr 15, 2002 06:40 PM
