found some 41lb injectors!!
Old May 29, 2002 | 06:27 PM
parish8's Avatar
single digit dreamer
Default found some 41lb injectors!!
i pulled one of my injectors and took a pic and some measurements and sent that off to http://www.rceng.com/index.htm
they found one that is rated at 35.2lb/hr at 43.5psi, that is equal to 41lb/hr at our 59psi. they tell me it is a direct replacement, conector and all.
they have them in stock and ready to ship but my god do they want alot of cash for those things! $85 ea!!! well i have ls1edit and a couple of smaller pullies just waiting for a fuel fix so i had to order them. so far i have only gained .4 in the 1/4 with the 6.0 and yank swap and i know there is alot more potential than that. just bumping the boost up from 3 to 6 or so psi should be .3 or more.
Old May 29, 2002 | 07:14 PM
2000 Camaro SS's Avatar
Default Re: found some 41lb injectors!!
What I was told is their injector will not go static at all. This is one reason they cost so much.
Old May 29, 2002 | 07:23 PM
parish8's Avatar
"static" what is that and is it a good thing?
Old May 29, 2002 | 08:33 PM
oxidizr's Avatar
Moderator / Sponsor
"Static" is an occurance which happens when signal exceeds the threshold of the injector (duty cycle)...too much pulsewidth. When injectors go "static" they shut-off...obviusly this is not a good thing. This is a common problem dry nitrous users run across.
Richard
Old May 29, 2002 | 10:04 PM
XLR8NSS's Avatar
Adkoonerstrator
Do you have a part number for the injectors your getting?
They sound like they will be perfect for my future setup also.
Thank <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
Old May 30, 2002 | 12:18 AM
y2khawk's Avatar
"Going Static" DOES NOT MEAN they shut off
Static operation refers to a duty cycle of 100%. While it's not a good thing for a few reasons, the biggest problem is you can no longer increase fuel delivery.
the major issus with it are overheating of the injector, you can get into a non-linear range of the injector (may not flow the rated mass of fuel).
FWIW, alot of injectors are rated at static flow
Old May 30, 2002 | 01:02 AM
red53gmc's Avatar
Yeah, post the part numbers that you are getting.
Old May 30, 2002 | 03:02 AM
parish8's Avatar
they didn't give me a part number but when they show i will give you all the numbers off of the injector, then you can go out and find them really cheap and rub that in my face. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> i am just happy to have something in the mail so i can start tuning and cranking up the boost.
adunphy
Feb 22, 2016 06:38 PM
RONIN LSX
Aug 11, 2015 12:03 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
