flexalite fans
Old Jan 22, 2006 | 12:10 AM
jus1975's Avatar
Default flexalite fans
I have the flex fans and there wiring harness. I also have the Nelson harness. Which do you guys think is better. Are there any pros and/or cons on either harness. the Nelson harness looks more like factory but thats the only difference I see.
Old Jan 22, 2006 | 07:20 AM
Breeze's Avatar
11 Second Truck Club
Does'nt the Neson harnes use the PCM. If it does I would use it.
Old Jan 22, 2006 | 11:11 AM
Desert Reaper 5.3's Avatar
What is the advantage of running fans through the PCM? I looking into getting a set. Thanks
Old Jan 22, 2006 | 01:29 PM
RoninsDenali's Avatar
I have a set of Flexalite 282's which i think are great. Although without hesitation i used a nelson harness vs. the VSC for several reasons.
-the nelson harness looks a lot better.
-PCM control on the fan on/off point is easier to control in my opinion.
-PCM activation points are probably more reliable.
-Not having to put a temperture probe through the radiator core.
-Did i mention it looks a helluva lot better?
Although afterwards i did realize a minor negative aspect. There really is only one speed for the fans, both motors running in series. Granted the 282's move a lot of air at half power and i've never run into any temperature problems. Of course if i need fullpower i'll just hit the AC button for that 757 Turbine sound
Old Jan 22, 2006 | 02:56 PM
SnakeOiler's Avatar
Originally Posted by RoninsDenali
... There really is only one speed for the fans, both motors running in series...
Not exactly. If using the three relay setup, the fans run in series (if just the temp fan kicks on) or parallel (if the a/c fan kicks on). When in series, both fans run at half speed, when in parallel they run full speed.
Using the 2-relay setup, boths fans are always in parallel mode (full speed).
Old Jan 22, 2006 | 03:19 PM
Heh ok, maybe i should have been more clear with why i said what i said. The PCM can only directly control 1 relay. Which is why i stated both fans running in series. But then again if you reason out it being hot out, engine needs more cooling, you need more cooling too so the AC is on running both fans in parallel.
Old Jan 23, 2006 | 12:57 AM
TXsilverado's Avatar
my vsc was always a problem. never liked it and gave it away to give another guy on the forums a headache(cant remember who i gave it to). i was always worried if the fans were working or not because they gave me so much trouble. got a nelson harness and my fans working properly is the last thing on my mind when i drive down the road now....now i just wory about if i have enough gas money to make it to point B
Old Jan 23, 2006 | 01:41 AM
black_yukon's Avatar
The fans work great, the VSC sucks. I've burnt out 3 already.
Old Jan 23, 2006 | 02:18 AM
GMC_DUDE's Avatar
I also burned out the VSC and their fuse nearly caught my truck on fire. Replaced the vsc with a Delta Controls unit, and the fuse with one of those sugar-cube shaped ones with the tabs on the side that you can bolt the wires to. Works great.
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
