Engine coolant drain plugs...
Old Aug 28, 2010 | 08:02 PM
cali92rs's Avatar
Default Engine coolant drain plugs...
Where are they? In relation to what? I was under the car today and couldnt find them...thanks
Old Aug 28, 2010 | 08:12 PM
MikeGyver's Avatar
There's a drain **** on the left (driver's) side of the radiator, with a hose attached. You are supposed to turn the hose down and open the drain.
Old Aug 28, 2010 | 08:22 PM
cali92rs's Avatar
Thanks for the response
But I was referring to the ones on the underside of the engine blocks...do these trucks not have those?
Old Aug 28, 2010 | 08:23 PM
Doobie's Avatar
I have an 03' with a 34" radiator and it has NO drain ****. I pull the lower radiator hose to drain mine and it does make a for a messy job. GM saving a few cents where ever they think they can squeeze it from.
Old Aug 28, 2010 | 08:25 PM
cali92rs's Avatar
Yea, I noticed my '05 doesnt have one either...greeeeat
Old Aug 28, 2010 | 08:31 PM
MikeGyver's Avatar
There is a brass plug on the engine with a female hex. I can't remember the size for sure, but it is big. I think it is 17 mm. I don't remember the location, but it is there.
Old Aug 29, 2010 | 04:01 PM
06Sierra2's Avatar
^^^x2
Old Aug 29, 2010 | 04:38 PM
Formerly 99-2door-08/30/2010
The plug in the engine is on the left side of the block near the PS pump.
Old Aug 29, 2010 | 08:32 PM
blsnelling's Avatar
That big brass plug can be a bear to remove too. I had to chisel mine out in the LQ4 I'm rebuilding right now.
chopperloco
Jul 10, 2016 10:45 PM
Noah Burns
Sep 7, 2015 05:50 PM
hartinclay
Aug 3, 2015 07:03 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Mzay
Jul 6, 2015 11:03 PM
