E-Fans worth it?
Old Oct 2, 2004 | 06:45 PM
  #21
jlpearl's Avatar
Any idea if the '05 fans will reftrofit back for us guys with old trucks like '03s and '04s?? ~josh
Old Oct 2, 2004 | 07:56 PM
  #22
eallanboggs's Avatar
I your using a VSC you can't use the PCM to turn on the fans because the thermistor the VSC uses has 2 wires that go to pins 10 and 11 of the VSC while the PCM output is only 1 wire. You can use the PCM output to pick a relay to turn your fans ON. I believe the PCM output is a ground so you'll need to wire the relay with a constant 12 VDC source on one side of the relay coil and wire the other side of the coil so it is looking for ground to energize it. You tie the side of the relay that is looking for ground to your PCM output. When the PCM provides the ground to the relay coil the relay will be picked and your fans will come ON.
Old Oct 2, 2004 | 09:10 PM
  #23
FILE's Avatar
http://james.jaguar.net/agreif/fans/fanstech.htm
Old Oct 2, 2004 | 10:20 PM
  #24
SnakeOiler's Avatar
Originally Posted by 2000_Silverado_SS
So which wire do I splice into off the pcm to get the feed to turn on my efans? What color is it? About where is it located?
Pin 42 on the blue connector. This hole is not used (empty) on the truck pcm, but is the circuit that will set a ground based on the coolant temp - of course you need to change the computer to for the temp setting.
Old Oct 2, 2004 | 10:24 PM
  #25
SnakeOiler's Avatar
It looks like they might if you have the large radiator. See this thread: https://ls1tech.com/forums/showthread.php?t=198125
Old Oct 4, 2004 | 07:43 AM
  #26
jlpearl's Avatar
thanks ~josh
Old Oct 30, 2006 | 02:43 PM
  #27
04BlackGmc's Avatar
10 Second Club
just marking...
GRRR65GTO
Oct 10, 2015 04:37 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
