E-Fans worth it?
Old Sep 28, 2004 | 10:28 AM
TG02Z71's Avatar
Question E-Fans worth it?
I have seen many posts on this subject. Are the e-fans worth the trouble for horsepower you get back. I have heard all sorts of numbers. On a stock 5.3l whats it worth? Also what brands are the best and most easy to install? I am not worried about small things as far as fabrication goes because I work at a cnc maching type shop. thanks.
Old Sep 28, 2004 | 10:42 AM
marc_w's Avatar
I did two mods at the same time (fans and tuning), so I can't really acurately comment on the gains. I did get a good increase in MPG (2+, if I remember right), and noticed the engine reved more 'freely'.
I think Flex-a-Lite fans are the best drop-in kit. If you are nervous about the controller issues, you can go for the DCC fan controller for about $100. Mine's been perfectly reliable, even with the notorious FaL fuse holder.
My fans required a little bit of fabbing to get them to fit to 'my' specs. I had to take a little material off the 'ears' that sit in the slots on the composite sides of the radiator. Nothing difficult at all.
Old Sep 28, 2004 | 11:30 AM
Scream's Avatar
MOOBIES Moderator
I've been running LT1 junkyard fans that I bought for $75, and couldn't be happier with them. I'm not sure how much I gained, but the SOTP-meter was pleased. And the truck runs cooler, even in the FL heat with the A/C on!
Definitely a worthwhile mod!
Old Sep 28, 2004 | 01:06 PM
FILE's Avatar
I agree.... It's a worthwile mod to do specialy if you can get some cheap ls1/lt1 fans at a junk yard.
Old Sep 29, 2004 | 04:23 PM
TG02Z71's Avatar
Thanks for the info guys! If I get a used set from the bone yard what do I need to get them to work with the truck? Any special wiring or sensors?
Thanks.
Old Sep 29, 2004 | 04:26 PM
Scream's Avatar
MOOBIES Moderator
You can get pigtails and a relay kit from Nelson Performance, and even have your PCM re-programmed to control the fans. I just had mine wired up through 2 30-amp relays, and I turn them on and off with a switch on the dash.
Old Sep 29, 2004 | 06:36 PM
WillPewter2000's Avatar
Is there a way to run the fans without the pcm and no switch I am thinking about doing this, but would like a factory turn key operation?
Old Sep 29, 2004 | 06:43 PM
Flyer's Avatar
To me, the fans were worth getting rid of that monster mechanical fan screaming in the front.
You can make you're own wiring harnedd too, but that's a bit moe difficult.
Old Sep 29, 2004 | 08:29 PM
gametech's Avatar
If you ever have to change your AC belt, you will be glad to not have the factory fan and shroud in the way. If you want a turnkey setup, flexalite has a vsc that controls fan turn on and speed based on engine temps, but their controllers are notorious for a variety of problems.
Old Sep 29, 2004 | 09:43 PM
I would like to run ls1 fans with a turn key operation what other controllers are their to use?
