E-Fans worth it?
Old Sep 29, 2004 | 10:25 PM
FILE's Avatar
Here you go...
http://www.ls1truck.com/howto/pcmfan...ng_frames.html
Old Sep 29, 2004 | 10:34 PM
WillPewter2000's Avatar
appreciate it one more question. Where do I get a quality controller?
Old Sep 30, 2004 | 03:32 AM
dkubricht's Avatar
Does the DCC run just like the VSC?
Old Sep 30, 2004 | 08:58 AM
TigerFan187's Avatar
Are the LS1 fans a dual setup?? 2 fans?
Old Sep 30, 2004 | 09:26 AM
FILE's Avatar
Yes it is.
Old Sep 30, 2004 | 10:32 AM
slow4.8's Avatar
I got a mustang gt fan and cut off the brackets to mount inside the stock fan shroud for the sleeper factor. Also, I hard wired the fan up to a switch on the dash.
Old Sep 30, 2004 | 06:39 PM
eallanboggs's Avatar
I just installed the Flex-a-lite 292 dual fan kit on my 2004 Silverado. When I initially installed the kit the water temp didn't change (205 F) and the fans didn't come ON until the engine got up to operating temp. I then installed a 160 F thermostat and the water temp dropped to 185 F, but the fans wouldn't come ON so the water temp gradually crept back up to 205 F at which point the fans would cycle ON and OFF. The LS1 cools so well that I can idle this engine with no fan and it takes quite a long time for the engine to reach operating temp. I checked the resistance of the Flex-a-lite thermistor in a pot of water using a Digital Thermometer and a DVM. It's 750 ohms at 212 F/100 C. I wanted my fans to come on at 185 F which was 1.1 K ohms so I had to FOOL the VSC into thinking the thermistor was seeing 205 F when it is actually 185 F. I used the parallel resistance formula: Reciprocal of the sum of the reciprocals and came up with 1 K ohms. I put a 1 K ohms resistor in parallel with the thermistor across pins 10 and 11 of the VSC and now my fans come on at 185 F at the 60% rate. It the water temp goes up any the fans gradually ramp up to 100%. They're working just like I want with my little resistor mod. 20 cents at a local electronics store.
Old Sep 30, 2004 | 09:01 PM
marc_w's Avatar
Awesome Ed! I actually JUST replied to your PM about this... Sorry it took so long, I had to stew on it a bit to try to help figure out what was going on.
I was off... I was thinking a 2K ohm resistor was what you needed...
Old Oct 1, 2004 | 05:41 AM
nativetexan's Avatar
13 Second Truck Club
You guys are killing me. Thanks for the info!
Old Oct 2, 2004 | 12:23 PM
So which wire do I splice into off the pcm to get the feed to turn on my efans? What color is it? About where is it located?
