E-Fans worth it?
#22
I your using a VSC you can't use the PCM to turn on the fans because the thermistor the VSC uses has 2 wires that go to pins 10 and 11 of the VSC while the PCM output is only 1 wire. You can use the PCM output to pick a relay to turn your fans ON. I believe the PCM output is a ground so you'll need to wire the relay with a constant 12 VDC source on one side of the relay coil and wire the other side of the coil so it is looking for ground to energize it. You tie the side of the relay that is looking for ground to your PCM output. When the PCM provides the ground to the relay coil the relay will be picked and your fans will come ON.
#23
#24
Originally Posted by 2000_Silverado_SS
So which wire do I splice into off the pcm to get the feed to turn on my efans? What color is it? About where is it located?
#25
Originally Posted by jlpearl
Any idea if the '05 fans will reftrofit back for us guys with old trucks like '03s and '04s?? ~josh
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
