Degree thermostat?
Old Oct 19, 2009 | 04:21 PM
Default Degree thermostat?
Trying to figure what thermostat I should get while I have the motor out? I've seen some people do 160 and 195. I'm installing e-fans, along with cam heads and tb converter before I do swap.... Would 180 degree be good w/o going to low? Or jus stay 195
Old Oct 19, 2009 | 04:24 PM
00ChevyScott's Avatar
Wearin' da big hat
keep the stocker.
Old Oct 19, 2009 | 04:44 PM
nonnieselman's Avatar
you can always do the BB mod
Old Oct 19, 2009 | 07:20 PM
FERGHOE's Avatar
Old Oct 19, 2009 | 07:27 PM
https://www.performancetrucks.net/fo...85#post3782585
Old Oct 19, 2009 | 07:28 PM
Old Oct 19, 2009 | 08:12 PM
terravast4's Avatar
for any real benefits you need to tune for the mod. If you run a 160 stat you can run a more agressive tune.
Old Oct 19, 2009 | 10:34 PM
thanks for the info guys
yeah, i was gonna run the truck to wheatley as soon as i get the motor in and running. i was thinkin 180 if anything maybe jus put another 195 in..... i know its better internally for engine to run lower stats, but whats the downfall?
L7 Sierra's Avatar
Keep the stocker if you drive your truck alot. To low a temp ruins cylinder bores, and a high temp one pretty much stops cylinder wear. 160 can be low enough and 180 is high enough.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Lthompson
Sep 30, 2015 06:48 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Justin87gn
Sep 10, 2015 12:06 PM
xerox17
Sep 5, 2015 01:23 PM
