crankcase ventilation
Old Jun 10, 2007 | 02:36 PM
  #21
moregrip's Avatar
what a rush!
don't think I'll be running a breather, I'll somewhat mimic the stock setup
Old Jun 10, 2007 | 04:48 PM
  #22
kbracing96's Avatar
Stock setup runs a "breather" That's what the pass side valve cover nipple running to the tb before the blade does. Lets it pull fresh clean air from there.
Old Jun 11, 2007 | 08:10 PM
  #23
moregrip's Avatar
what a rush!
it will be close to a stock radix type setup but not exact, from what I'm reading it should be a non issue. If it becomes one, I can always add a second breather.
Old Jun 15, 2007 | 07:52 PM
  #24
moregrip's Avatar
what a rush!
any other thoughts?
Old Jun 15, 2007 | 08:16 PM
  #25
I'm trying a LS6 valley cover and PCV setup I've never had any issues with the stock Radix setup.
Old Jun 15, 2007 | 08:26 PM
  #26
2004SSS's Avatar
so your going to run straigh to a vacuum? im getting ready to plumb mine tommorrow. i have an amw catch can i plan on running. ill be running each pcv ( from the valve covers) to a t hose connection then to the oil catch can then to a spot on the intake pre blower so it always see vacuum and can catch any oil in case. hopefully i dont pull to much vacuum like bill did though.
Old Jun 15, 2007 | 08:32 PM
  #27
moregrip's Avatar
what a rush!
I will run a catch can as well, just not sure about running a one way valve or not
lr4 colorado v8
Sep 11, 2011 02:17 PM
sharpshooter
Mar 15, 2008 03:25 PM
moregrip
Sep 7, 2007 09:34 PM
Superado
Jul 3, 2006 07:35 PM
TG02Z71
May 31, 2006 09:51 PM
