crankcase ventilation
Originally Posted by 2004SSS
whats the sensor for? that an interestign set up grip , any info on it? im also lookign for wxactly to do with my pcv system .
it says those are used for dry sump or vacuum pumped assisted. i wonder if he has a vacuum pump . i know with vacuum its easier on piston rings so id like to have vacuum on my crank case but not have oil in my intake. so i think i may be sticking with the normal pcv from the valve covers with a catch can , now to find an amw for a decent price.
Originally Posted by jetmann
Thats A very good breather system on that vette.Is that what you are doing to your truck Devin?
after some further research I think I'm going to keep it simple; I'll use the drivers side breather tube connected to a high quality catch can connected to the back of the Radix J-Tube.
Only question is should I use a one way valve?
Originally Posted by kbracing96
You shouldn't need a check valve, as the J-tube only ever sees vac and not boost. Also, if you connecting it to the J-tube, you should have a breather to allow fresh air into the crankcase.
I guess at some boost point the PCV system is no longer useful. This is a good thread and hope some good ideas come out of it
Bill
