coolant in cab?
Old Jan 26, 2004 | 11:57 PM
sleepersilverado's Avatar
Default coolant in cab?
where all is the cooland routed in the cab for like the heater core. i just thought of something today. right on the tranny hump up there under the dash on the carpet there has been a stain i have cleaned a fiew times. it was like a rust collor not too noticeable on graphite interior. i never realy thought about it or what it could be but there is deffinatly a slow leak of some sort. does any body know what is around that area?
Old Jan 27, 2004 | 01:09 AM
z7199's Avatar
Maybe sweat from A/C had a similar problem with my 2000 silvy.
Old Jan 27, 2004 | 01:14 AM
With that color, you may have a pinhole leak. If under warrenty get it repaired!
Old Jan 27, 2004 | 02:09 AM
like i said it is like a rust color that is why i think it is possibly coolant. waranty is long gone. i guess i will just have to tare it apart next time i am home.
so z were exactly was the prob you had mine is a 2000 an like i said it is on the tranny hump. but i dont get why it is the rust looking color.
Old Jan 27, 2004 | 05:57 AM
M.Roberts's Avatar
I would guess a heater core leak, mine did with 5k on it, luckily under warranty. You should be able to smell the coolant, if it is coolant, and the leak I had caused the windows to fog up horribly. I hope that is not what your problem is .
Old Jan 27, 2004 | 06:34 AM
mudz5.3's Avatar
The rust color is because of the 150k antifreeze you most likely have in your system. It is a reddish/pink color. If your antifreeze has been changed to a green, regular 50k antifreeze than you most likely have problems with rust build up and you need a flush. I would bet on the first scenario though. I have been smelling antifreeze in my truck for a month or so now, but my coolant level has never dropped. I figured I had a pinhole but still haven't checked. Come to think about it, I haven't smelled it an a week or two.
Old Jan 27, 2004 | 07:48 AM
had the problem with condensation dripping from under my dash and kick panel. Never really new what it was but it cost me to rip out the carpet and pad. Scrub everything down because mildew was growing under neath the carpet. Here in oklahoma during the summer I use the AC alot. since it gets to 105. It was the perfect hidden spot for mildwew and all that other nasty stuff. Have you ever driven a truck with dumps without carpet. Damn its loud.
Old Jan 27, 2004 | 11:07 AM
that is funny you say that. i had my pass seat out and it was quite a bit louder so i could imagine how loud it would be with out the carpet.
Old Jan 27, 2004 | 11:20 AM
yeah I had 2 1chambers with 6 inch pipes dumped right behind the cab. talk about to loud. Interior vibrated so bad I couldnt stand it.
6.0l RST
Nov 23, 2015 11:30 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
abey15
Sep 25, 2015 09:30 PM
2plus2
Sep 13, 2015 07:17 PM
