Exhaust ? Single or True Dual with X pipe
Which exhaust is better for performance, a single muffler or true duals with an X pipe and factory cats. Also which is the best pipe size for each? I plan on exiting the pipes right before the passenger front tire. I am planning on using either Magnaflows or possibly PVmufflers. Also, those with duals have any problems with SES lights? Any opions would be great.
This my first mod to the truck. Mods planned in order:
Dual Alt with batteries
Electric fans with low thermostat
Dual air intake
Programmer
Headers
Dual air intake
Programmer
Headers
It kinda depends on what you plan on or are currently running. I've got the stock exhaust with a replacement Flowmaster and it works just fine. If you plan on going with headers then I would go with the true dual exhaust. A 2.5 pipe would be good enough for about 450 hp. If I'm wrong about that then someone please correct me. I can't see the ses light being a problem if the exhaust setup is right.
From my research, I've heard that true duals will sap some of your end torque until you go boosted. I ended up going with a Corsa catback and no regrets here. The only SES problem will will encounter are if you go with uncoated long/mid headers and removal of the cats without using o2 sims or deleting the emissions with LS1edit or a custom PCM.
With the factory cats in place you shouldn't lose too much backpressure; therefore, maintaining most of your low end. It all comes down to personal preference.
Jim
Raggedz71
Jul 29, 2016 10:20 AM
thewrx
Aug 12, 2015 08:28 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
