converter lockup question
Old Feb 28, 2005 | 12:02 PM
slowprocess's Avatar
Default converter lockup question
Guys, I've been putting up with this for awhile, but I finally have to ask about converter lockup. Just easing around town, when I get converter lockup at around 30-35mph, the power just falls off the planet! I know that I sacrifice some low end with the cam, but I'm now starting to feel the converter is locking up too quickly. On a cold morning, the converter will take awhile to lock up, and it feels great getting up to my cruising speed.
How should the converter be set up? What should I tell Allen I want it to do? The truck is awesome running down the track and at faster accelerations, but a simple cruise around town is pretty bad. It just doesn't seem to me the converter should be locking at such a low mph on such a low acceleration. Am I totally off base here, or is this something I can remedy? Thanks guys.
Jeremy
Old Feb 28, 2005 | 12:32 PM
900Z1's Avatar
You can raise the MPH that the TQ Converter locks.
I have mine set to lock at low MPH on normal mode for better MPG
and have Haul mode set to lock during shifts and OD only.
Use Tow/Haul for the best of both worlds.
Just my 2 cents
Old Feb 28, 2005 | 12:40 PM
BigKID's Avatar
That is exactly what you have to do. I have mine set up not to lock up before 42mph no matter what in od and have the other settings tweeked from there. Best thing to do is figure out what mph you want it to lock up at what throttle position since that is what the table is scalled on. (mph vs throttle by gear)
Old Feb 28, 2005 | 05:30 PM
KeukaZ71's Avatar
mine locks up at about 40 mph in OD
it seems to work fine.
Old Feb 28, 2005 | 05:40 PM
ridnlow's Avatar
Ive got the same converter and i notice the same thing.. I havent had an update from allen since installing the converter.. Everything works great its just when it locks up just cruising around it really falls on its face..
thunder550
Oct 8, 2015 04:53 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
