Chirping under hood
Old Apr 7, 2011 | 10:57 AM
04LTSilverado's Avatar
Question Chirping under hood
Just did a cam and stall swap on truck. Also had all gaskets replaced. Once I drove away from shop I noticed a constant chirping under hood. It never squeels, just chirps. The truck won't be tuned until Tuesday and it doesn't idle so hard for me to troubleshoot. It never goes away up to 3K, since the truck isn't tuned I haven't gone over these rpms. Any ideas fo what it could be?
The shop that did work is a long ways from house and don't have the down time to drop it back off. Hoping it something I can do myself.
Old Apr 7, 2011 | 11:40 AM
bullygoat's Avatar
Does it sound like a belt chirp? It's possible some fluid got on a belt or pulley and that's whats causing it now.
Old Apr 7, 2011 | 01:52 PM
Sounds like more of a pulley. But I've also read about the cam synchronizer?
Old Apr 7, 2011 | 01:59 PM
And I've put about 100 miles on it. If any fluid on a I would imagine the sound would have changed. It's been the same constant
Old Apr 7, 2011 | 07:10 PM
.James.'s Avatar
hmm, only chirping or barking should be the tires imo
Old Apr 7, 2011 | 07:32 PM
Country Boy's Avatar
Senior Member
idler pulley. Ive seen it happen a lot. Ive seen some a/c compressors make the noise also.
Old Apr 7, 2011 | 07:39 PM
smokeshow's Avatar
Mod with training wheels
Could be idler pulley. Could be the belt. I had a squeaking problem a while back that was constant and loud. No matter how much I cleaned the belt it wouldn't go away. Ended up buying a new belt, noise went away.
Old Apr 8, 2011 | 12:22 AM
BadAssChevy327's Avatar
check a/c belt. make sure its on all the way. if i get on it and let off before it shifts it slides the belt and makes the most annoying chirping noise. i need to change belt and tensioner since i dont even need a rachet to take the tension off it lol
Old Apr 8, 2011 | 08:24 AM
Off today so going to buy both. Thanks for the help guys. After I fix this dilemma and Wheatley gets ahold of Tuesday then hopefully the tires are the only thing making noises! Sure I will to after I stop at the gas station too!
cheyenne383
Nov 13, 2015 09:24 AM
peebzies
Sep 30, 2015 03:03 PM
97_ek
Sep 23, 2015 09:16 PM
Roody0209
Sep 17, 2015 09:06 AM
kmcn47
Sep 17, 2015 01:12 AM
