Check engine light obd2 port?
Old Jun 25, 2013 | 07:27 PM
Txblue's Avatar
Default Check engine light obd2 port?
Not sure if I'm posting this in the right spot... My check engine light came on today leaving work. So I went back to the shop to use my snap on scanner to look up the code... I couldn't get the scanner to work. I kept saying it had no communication with my truck... I did notice that usually when I hook that scanner into an obd2 port it comes on but I was having to turn the scanner on manually... I assumed the scanner messed up somehow and The truck runs and sounds fine so I assumed it was a sensor of some kind so I went to oreillys to have them pull the code and ran into the same problem... It's a 2001 silverado 5.3 I put a newer 5.3 engine, cam, long tubes and mail order tune from Nelson in may and its been running fine no problems... Any ideas?
Old Jun 25, 2013 | 08:18 PM
Suburbazine's Avatar
your cigarette lighter fuse is blown.
Old Jun 25, 2013 | 08:34 PM
AJII's Avatar
Yep. Its in the box under the hood
Old Jun 25, 2013 | 08:46 PM
Txblue's Avatar
The aux power 20a fuse?
Old Jun 25, 2013 | 08:48 PM
charcoal03silvy's Avatar
I thought there was one that says cig something... if not then that's the one i believe
Old Jun 25, 2013 | 08:58 PM
Txblue's Avatar
I only see an aux 20a fuse no cig fuse and its good. My truck has three aux ports inside well I guess two aux and one cig in a row... My radar detector is in one phone charger in another and nothing in the third both of those work but I plugged my charger into the third and it didn't come on... But shouldn't all three be on the same fuse
Old Jun 25, 2013 | 09:01 PM
Txblue's Avatar
Oops sorry I'm blind or one too many lol. found it it said "cigar" and yes it's blown... I never have had anything plugged into it no cig lighter nothing... Any ideas on why it blew?
Old Jun 25, 2013 | 09:05 PM
probably ever 3 of 5 vehicles I tune has one that's blown lol. If you overload the ports they can draw too much current.
Old Jun 25, 2013 | 09:14 PM
Txblue's Avatar
Ok thanks.. Ill replace it tomorrow and hook my scanner up to it to see why the check engine light is on
Old Jun 26, 2013 | 12:29 AM
AJII's Avatar
The third one is on that fuse. The other two ports are on another circuit.
tweeder
Sep 18, 2015 11:02 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
