catalytic headache bullsh!t damn it f%ck
Old Dec 16, 2009 | 02:59 PM
  #31
eallanboggs's Avatar
Any decent scan tool(not code reader) can tell you if you're rich or lean. Just monitor your STFTs and LTFTs. The closer to ZERO the better. If your 02s toggle above and below 450mVdc your fuel trims should be withing spec. A gutted cat is a good cat.
Old Dec 16, 2009 | 05:38 PM
  #32
EVILGMC's Avatar
i am going to review my dyno tune charts and get over to my old shop and borrow the TECH2.
spoke with the guys at random technology today...lots of good info.
Old Dec 16, 2009 | 07:24 PM
  #33
phasemaster1's Avatar
Even if you mounted them back further what if you did like sts guys and wrap your exhaust to keep in heat?
Old Dec 16, 2009 | 07:39 PM
  #34
EVILGMC's Avatar
i am going to start of with air fuel diagnostics.
then going to add new cats...either random technology 100 cpi metal or slp 200 cpi metal cats. will mount them a bit down stream if possible.
also going to put in two more mufflers after the axle to get it even quieter.
Old Dec 16, 2009 | 08:54 PM
  #35
terravast4's Avatar
Originally Posted by EVILGMC
do you have any photos? where did you mount the x-pipe?
I will try and get a pic this week-end. the x-pipe is right after the cats. both cats are after the trans crossmember then the drivers side 45's to the passenger side into the x-pipe.
Old Dec 16, 2009 | 08:57 PM
  #36
terravast4's Avatar
I don't think it is so much the heat destroying them as much as the velosity of air at the collector area just forcing the substrate out of it's body. My passenger side looked like wadded up tin foil when I found it pinned against thr rear o2 sensor
Old Dec 16, 2009 | 09:17 PM
  #37
SLOXCAB's Avatar
i have my stock cats if you need them
Old Dec 16, 2009 | 10:06 PM
  #38
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by terravast4
the cats are too close to the collector. I installed my magnaflows with ceramic internals after the trans crossmember and have had no issues i blew out my stainless works in one day at the collector.
Just a note...in a stock setup the cats are supposed to be as close to the collector as possible to allow them to heat up to work properly...I could see how in a performance application this may be a problem, especially if the tune isn't spot on, or the engine is boosted and running very rich at WOT...
I've heard of one or two people blowing out their StainlessWorks cats...mine have been going strong for almost 5 years now, not sure if they've changed their cat supplier through the years though...
Old Dec 17, 2009 | 01:18 AM
  #39
laynlow77's Avatar
can i get a pic/rundown of your current setup? sounds like were going for the same thing.... a badass truck that is quiet!
hmmm thats how im gonna do mine when i see yours.
Old Dec 17, 2009 | 10:39 AM
  #40
EVILGMC's Avatar
ill get under it this weekend and take some pictures. maybe even an idle video...
