Cammed my truck. Now having problems
Old Jul 25, 2012 | 11:01 AM
ivan_key's Avatar
Default Cammed my truck. Now having problems
Ok I have. 08 silverado that I just put a lot of money into, got the tsp224r cam package, circle d 3200 stall, lts, pry and 4.11 gears. My problem is that it runs alright but cuts out sometimes at all Rpms and it's hard to start. Started fine before the cam but not takes a good 5-7 seconds to fire up. Tuner said their was nothing he could do to fix those problems.
Old Jul 25, 2012 | 11:12 AM
ayousef's Avatar
something to do with the cam sensor
Old Jul 25, 2012 | 11:27 AM
canada4g63's Avatar
Have you checked for lose conections?
Old Jul 25, 2012 | 11:28 AM
ivan_key's Avatar
i just checked the check engine light and im getting codes for all o2 sensors, witch the rear two were turned off, and i do have a cam sensor code, the cam sensor was fine before the cam install, it shouldnt have got damaged in any way.
Old Jul 25, 2012 | 11:30 AM
ivan_key's Avatar
ya i checked the things i unhooked witch was o2 sensors, cam sensor, mass air, coil packs thats all i unplugged and they seem to be all good, also has new spark plugs witch are gapped at .060
Old Jul 25, 2012 | 11:32 AM
Post the codes that you are throwing... More than likely its not a bad cam sensor but some other reason, but they have gone dead before..
Old Jul 25, 2012 | 11:39 AM
ayousef's Avatar
did your truck have dod?
also, I still think its a cam sensor thing. Thats usually the only thing that could have gone wrong during a cam swap and causes a car to take a few seconds to start, THAT IS NOT tune related.
Old Jul 25, 2012 | 11:49 AM
The cam sensor could tell you that the cam is "walking" which I doubt it is that or could be the DOD... I doubt it has anything to do with the cam gear needing to be switched... On an my motor swap with the LS2 I had to change out the cam gear to get rid of that code. So that is where the trouble codes that it is throwing will help us out.
Old Jul 25, 2012 | 12:21 PM
ivan_key's Avatar
i did not have dod, the only thing i changed was i went from a single bolt cam to a 3 bolt and used a new ls2 cam gear
Old Jul 25, 2012 | 12:23 PM
ivan_key's Avatar
codes i pulled are
p0141
p0161
p0341
p0140
p0160
p0036
p0056
