cam swap VS. 60' times
Old May 22, 2007 | 08:51 PM
  #21
RoosterMcCandles's Avatar
i always heard that a cam can make you lose low end. now its different?
A cam can make you lose some low end if you don't have a proper sized TC. If you have the stock TC and go to a cam that starts making power at 3000 or so, you will lose some low end...
Old May 22, 2007 | 09:04 PM
  #22
Sport Side's Avatar
Originally Posted by bluecajun5.3
why would you want a bigger cam if your 60' stayed the same?
isn't your goal to lower your 60'?
Good ******* post. It's obvious we hang out.
Old May 22, 2007 | 09:40 PM
  #23
TXsilverado's Avatar
i plan to restall the converter when the transmission breaks. i can always drop it that way.
Old May 23, 2007 | 10:34 AM
  #24
Quik's Avatar
5 year bitches!
exactly. its all about rpm and etc
a stock converter or small converter is the limitation to 60'
you can take a stock Fbody and be a ***** and launch at 1500rpms and get a 2.xx 60' or you can be a ballszzz ****** and launch at 6k and cut 1.6x [if stock rear will hold] all with the stock cam. same as putting a large stall in a stock fbody. put a 4k stall behind a stock ls1 and youll cut 60s all day long as long as you have the supporting mods
a cam will not affect 60' what so ever. the launch point in which you leave the line is what effects it. now if you have the wrong size converter which most on here do then youll 60 worst then you did before cause of the rpm range of the cam now
Old May 23, 2007 | 10:52 AM
  #25
Sport Side's Avatar
LOL... But why would you want to launch at greater RPM? What's at a higher RPM that is not at lower? What can affect power made at low/mid/high? LOL, I get what you're saying, but TQ/HP will peak at the same RPMs no matter how big you go with the cam, so basically you can reasonably only increase your launch RPM so far. (4800 app. max for TQ, 6200 app. max for HP w/ LS6 intake). With a auto, too big of a converter will push you past your workable RPM range. And w/ a street/strip vehicle matching your power to the size of the converter is very important because not everyone runs around with a 4400 converter.
Take for example my dad's Z06 (6 speed). It's a H/C/I stock shortblock. It makes 450rwhp, and he is dumping the clutch at 6700 RPM. It dead hooks w/ a 1.650' 60'. These cars can cut 1.40s on stock suspension, but he is out of workable RPM. One option is to increase HP/TQ to lower the 60'.
Old May 23, 2007 | 10:59 AM
  #26
Originally Posted by ap2002
hmmm... dont know?/
have you searched or looked around to see what kind of 60' other people are getting with 3.73's?? maybe the only way to lower it more is with 4.10's?
looking at the FTL im not doing too bad for a N/A ecsb on 3.73's
Old May 23, 2007 | 11:07 AM
  #27
Quik's Avatar
5 year bitches!
so are you saying no matter what cam is usedthe RPM peak will be the same? thats odd since i swore a mild cam of say the TSP TV2 peaks alot differently then the Trex
what one vehicle is claimed to be able to do isnt the same for the next identical vehicle.
but as other things involved so is power. power will help make up for some things in the 60' category
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
