Broke Crank Bolt
Old Oct 25, 2010 | 12:19 PM
  #41
moes04silverado's Avatar
ive done 3 motors, which doesnt make me any kind of expert what so ever...but I have used the same crank bolt 2 out of three time and never have any issues. The second time I used the GM bolt I used red loctite though. I was too cheap to go by a new bolt when the old bolt only had 400 miles on it
and as for swapping a crank while the motor is in a vehicle (any vehicle) no way! I'll pay to see this done and done correctly. Its to easy to pull the motor and put it on a stand
Old Oct 28, 2010 | 04:07 PM
  #42
aaronmc's Avatar
Well ended up picking up a new crank for $125. Got new main and rod bearings also. Should have it swapped in the next couple weeks.
Old Nov 2, 2010 | 07:43 PM
  #43
zittman's Avatar
Originally Posted by 02Denali6L
My installation tool has always been a propane torch... It really doesn't have to get that hot even. I have put on a stock one on this way several times and an underdriven one as well. Never any damaged threads as the balancer just slides right on by hand...
What do you heat up? the balancer or the end of the crankshaft?
Old Nov 2, 2010 | 07:48 PM
  #44
kbracing96's Avatar
The hub of the balancer. The heat expands it
Old Nov 2, 2010 | 07:50 PM
  #45
00ChevyScott's Avatar
Wearin' da big hat
Heating it works great, done it a few times. Just took a torch to the outside of the hub briefly to heat it up and slip it right on.
slowmo934
Sep 9, 2015 12:24 PM
Jblake
Aug 17, 2015 12:59 PM
vipergtrdj
Aug 6, 2015 10:19 PM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
