No start after a/c belt broke 3 MAF wires
Old Aug 21, 2015 | 03:28 PM
slowmo934's Avatar
Default No start after a/c belt broke 3 MAF wires
I have a 2005 Suburban with a front mount turbo kit and a built motor. The other day while driving my A/C belt broke and wiped out 3 of the 5 wires going to the MAF. MAF is disabled in my tune as it is SD only. When this happened truck shut off like the ignition was cut completely. I had it towed home so I can look into the problem. I terminated 3 wires for the MAF and used the other 2 which are for the IAT sensor now in a diffrent location. I now have a complete no start issue that resulted from these MAF wires getting hit. Truck will crank, shows no ignition voltage, and no injector voltage. With my HP tuners scanner im not seeing any codes. Also fuel gauge is pegged empty, fuel light is on, and all range,mpg,fuel used info is dashed out like this MPG -----. These MAF wires must have done something crazy???
Old Aug 24, 2015 | 08:20 PM
slowmo934's Avatar
Default Found Problem
I thought I checked all the fuses. Well I went back through again and found PCM B fuse blown. So lesson learned, if MAF wires short it will blow PCM B fuse and shut down all Spark, Injector, Fuel Info, and Fuel gauge.
Old Sep 9, 2015 | 12:24 PM
06murder's Avatar
Good thing bout gm. They have fuses for everything. Lucky didn't cooked the pcm.
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
wrb002
Aug 31, 2015 12:30 PM
fillpot
Jul 26, 2015 07:21 PM
