benefits of ls6 intake on our trucks.
Adkoonerstrator
I think Blacksheep may disagree with you on that Yelo.
The LS6 intake DOES flow better at higher rpm. The LS1, LS6, and truck intakes have been flowed against each other and while the truck intake is better than the LS1 it is not better than the LS6.
I think StupidFast may be putting one on his stroker. Hopefully he'll get some results.
I'm curious to see some more results with the LS2 intake. I wonder if you could use the Multec II injectors, 97-98 Corvette rails/crossover, and an LS2 intake on a truck. I know that the TB is angled slightly on the LS2--I wonder if it's angled enough to clear the idler?
If I can ever get this $%#@#@ tranny in, I plan on doing headers and a car intake. Should be good for 30+ rwhp. Or more?!?!?
The LS2 intake on the SSR is actually the same height as the truck intake, so the idler pulley, and waterpump neck wouldn't be a problem, and it even uses the same injectors. It might make for an extremely easy swap, but nobody has done it yet. Also, I would like to see some flow #'s for the LS2 intake for both the corvette, and for the SSR.
Adkoonerstrator
It would be interesting to see the LS2 SSR intake results. The only thing about that intake is the opening is not a true 90mm. It is 90mm at the TB opening and necks down as it goes into the plenum. There was a picture in the LS2-LS7 forum a while back.
but, hey...if you want the looks and the high-rpm performance go for it.....
Originally Posted by jimbo95z28
On the graphs of the LS6 intake I saw, it was better in every aspect, not just high lift or high rpm.
https://ls1tech.com/forums/showthrea...2C+test%2C+cam
"The last time they did the test with the stock motor and switched the intakes to see the results now they switched out 3 cams with each intake...
All dynoed withthe motor out of the car.
Comp Cam xr265hr
0.522/0.529 inch intake exhaust, 212deg intake/218deg exhaust, 114deg lob displacement
Truck intake= HP/TQ, 429/422 @5900/5000rpms
LS1 intake= HP/TQ, 450/439 @5900/5000rpms
LS6 intake= HP/TQ, 459/447 @5800/5000rpms
FAST intake= HP/TQ, 462/450 @5900/5000rpms
Comp Cam xr275hr
0.566/0.568 inch intake exhaust, 222deg intake/224deg exhaust, 112deg lob displacement
Truck intake= HP/TQ, 468/445 @6300/5200rpms
LS1 intake= HP/TQ, 462/442 @6300/5000rpms
LS6 intake= HP/TQ, 471/449 @6300/5000rpms
FAST intake= HP/TQ, 479/452 @6400/4900rpms
Comp Cam xer281hr
0.595/0.598 inch intake exhaust, 232deg intake/234deg exhaust, 112deg lob displacement
Truck intake= HP/TQ, 486/447 @6500/5000rpms
LS1 intake= HP/TQ, 484/445 @6500/5000rpms
LS6 intake= HP/TQ, 495/448 @6500/5000rpms
FAST intake= HP/TQ, 503/452 @6400/5000rpms"
14 Second Truck Club
That test with the 265 cam has to be a fluke. It was so close in the other tests, but 21hp off in that one? The other tests showed 3hp, and 9hp with the largest cam, and even then it had very similar toque (only 1 ft/lb diff).
