Anyone have a walbro intank and keep the bucket functional?
Old Jun 23, 2009 | 11:57 AM
SUX2BU's Avatar
11.0 Moderator
Default Anyone have a walbro intank and keep the bucket functional?
So my 255lph pump should be here tomorrow, and I've searched high/low but didn't find what i was looking for. I want to run this pump and keep the functionality of the bucket intact. I've installed dozens of these pumps in F bodies (98 and 99+), but their tank is slanted rear ward so it's not that big a deal. My tank is big and flat so i want the bucket to work like it does, don't wanna hack it up.
I don't want to be worried about getting on it if I'm at 1/4 tank. Also when i go to the track i like to be as low as possible on gas for weight savings. I know id doesn't seem like a lot but, full with 31 gallons thats comes out to about 194 lbs of gas. i like to run with about 5 gallons max, thats a weight savings of about 163 lbs.
Old Jun 25, 2009 | 04:50 PM
BLACK-SS's Avatar
i have issues with the bucket sucking dry if i go below 1/4 tank with the walbro pump
Old Jun 25, 2009 | 06:00 PM
hirdlej's Avatar
Why are you wanting to run the walbro? A stocker should be fine with your mods.....s
Old Jun 25, 2009 | 08:46 PM
SUX2BU's Avatar
11.0 Moderator
Did you chop up the bucket?
Old Jun 25, 2009 | 08:47 PM
SUX2BU's Avatar
11.0 Moderator
http://www.ls1truck.com/forums/power...o-project.html
Old Jun 25, 2009 | 09:32 PM
quicksilverado's Avatar
You will need 2 walbros for that setup. I had a single 255 lph and it could not supply enough fuel for my t76 at 12 psi.
Old Jun 26, 2009 | 12:21 AM
SpoolinChevy's Avatar
x2. When I put my 76 on, my single walbro was not enough. I instead just installed a Boost-A-Pump rather than another pump.
Old Jun 26, 2009 | 07:34 AM
SUX2BU's Avatar
11.0 Moderator
I have three walbro's actually. Got my new one in yesterday have one i've had and never used and an inline one i also never used. Just gotta pull the bucket out and see what i have to do to make it work. I was thinking of only going with one along with the 60 lb injectors (that's what nelson reccomended, but did say a double would be added insurance) but i would rather go ahead and put two inthere just so i don't have to drop the tank twice.
What size injectors were you running?
Old Jun 26, 2009 | 09:57 AM
I have 60 lb injectors. You will have to cut the bucket to fit two pumps. Or get someone to make or modify one for you. Mine is cut, so I run 1/2 tank of gas at the track and don't get on it much if the tank is below 1/4 full. Anytime I'm at wot I always watch the a/f gauge.
Old Jun 26, 2009 | 10:10 AM
silver-mod-o's Avatar
Hunt&Fisherator
My single Walbro and 60lbers are doing fine with my 347 and 78mm on 10psi... Holds 65psi in boost.
I just enlarged the hole in the bottom of the bucket and it fit fine. Ill be adding another 255 in tank or going to a very large single pump when I turn it up though... Ill probably run into issues right before long LOL...
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chavette
Oct 28, 2015 07:33 PM
Vortec350ss
Oct 10, 2015 09:11 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
97_ek
Sep 23, 2015 09:16 PM
