97 yukon 5.7 motor question, please help
Old Mar 13, 2006 | 08:45 PM
http://www.sdpc2000.com/catalog/120/...ate-Engine.htm
gotta love mid-80's cyl head technology in an overpriced package
http://www.blueprintengines.com/star...pecs&sye_id=12
just swap intakes, get a tune, and enjoy
Old Mar 15, 2006 | 11:30 PM
hog's Avatar
hog
I wouldnt use either of those engines, the 1st 1 is a ZZ4, it uses the aluminum L98 heads which wont fit in a Vortec truck.
The 2nd is a 383 that cheaps out and uses a flat tappet cam.
Much better to use the HT 383.
peace
Hog
Old Mar 15, 2006 | 11:34 PM
hog's Avatar
hog
hog -- does a 4 bolt main block and forged crank make more hp? i understand there are more differances, but i was referring simply to hp gains.
it is also not specified whether he wants 350 fwhp or rwhp.
james b. -- just add ls6 springs.
regardless, there is still a lot of grey area as to what he wants.
why does he want a crate engine vs. some simple mods?
The way you stated your answer, who would have known you were referring JUST to hp gains.
LS6 springs, are you sure about that?? Not disagreeing at all, there are folks that run the Comp 915 and 918 beehive springs on the L31 Vortec head.
Will teh LS6 springs and retainers fit on the L31 heads and valves??
Thanks man,
peace
Hog
Old Mar 16, 2006 | 08:13 PM
yes, the ls6 spring do fit.
has anyone else noticed the lack of conversation from the thread starter?
what exactly does he/she want?
Old Mar 16, 2006 | 08:16 PM
i guess these are exactly the reasons that i hate crate engines. i am the onlyone that builds my engines, regardless of mild/wild.
Old Mar 23, 2006 | 05:57 PM
backslap's Avatar
thanks for all the help so far, all ideas are great, i want to try to get at least 350hp from the rear wheels at this time, i was hoping on the just bolt an engine in and not do no work. i dont want to cut, grind, weld, press, fit or any other mcguyver ****. im done with all that. ive done only oldsmobiles and monte ss engine, at this point recommend me to a bolt in solution.
keep em coming, thanks so much
Old Mar 23, 2006 | 10:55 PM
383 short block, e-tec 200 heads, and a lt1 hot cam kit. should all work pretty well together. just have to check retainer and valve clearances.
kevin
ps: check with afr for a l31 intake pattern head, they will make more power than the edelbrocks.
Old Mar 25, 2006 | 08:29 AM
99kon's Avatar
What is the part number for that marine intake or who has one?
TXsilverado
Nov 26, 2015 10:54 AM
5.3Caprice
Nov 7, 2015 08:56 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
