8 rib pulleys
#22
Originally Posted by 1badsilverado
Where can I get a larger one at and how much?
I'd find the biggest pulley powerdyne makes for that charger then figure what size crank pulley it will take to spin that pulley to the 9psi level.
Do you have any plans for intercooling or alky injection? At 9 psi, you will need something.
You may want to check Reichard Racing first for an easier fix(just the charger pulley)
#23
I've been thinking about an intercooler a lot lately. Just trying to figure out the easiest and cheapest way to go. I'm gonna have to put the 6 psi pulley back on cause I can't stand the belt slipping every time I mash down on it. Does Reichard Racing have a web site? Powerdyne makes different pulleys for their supercharger. They even have an 8 rib one to.
#24
Lets say I get an 8 rib pulley for the supercharger and put a belt to match on it. Do you think I could machine the engines other pulleys to let the 2 extra ribs hang over the pulleys? Such as grinding off the shoulders on the stock pulleys.
#25
Adkoonerstrator
Try with ASP about a custom larger 8 or 6 rib crank pulley and new accessory pulleys. If anyone can do it they can.
http://www.aspracing.com/frame.htm
#27
Originally Posted by Black Blown 02
Heres the brace. Before the brace, I could push on the blower and flex the bracket about 30 thousandths. After the brace, it flexes about 5 thousandths. (checked at the supercharger pulley with a micrometer.)
Vortec350ss
Jan 12, 2016 10:36 PM
