8 rib pulleys
Old Oct 25, 2004 | 02:26 PM
2toneblown's Avatar
no i dont know if that would be the best idea
Old Oct 25, 2004 | 02:48 PM
Black Blown 02's Avatar
Originally Posted by 2toneblown
Blackblown are you running 11 psi on a P1 or D1 set up? We have done a couple of 8 rib set ups on some corvettes here at the shop and we think we could put one on a truck too. If my 6 rib plan doesnt work out then I am goin to try the 8 rib.
Mines a P1.
Old Oct 25, 2004 | 02:51 PM
2toneblown's Avatar
11 psi on a P1, pretty impressive. all you have changed is a riechard racing pulley?
Old Oct 25, 2004 | 02:56 PM
Yep. Bigger intercooler too. I saw 10.5-11 psi depending on the weather before the intercooler.
I have a 3.4" Reichard pulley and bigger idlers coming.
The only other thing I've done is fabbed a little brace to reduce supercharger bracket flex.
Old Oct 25, 2004 | 03:00 PM
2toneblown's Avatar
haha exactly why I am fabbing all new bracketry, nobody wants to believe me that flex in the brackets is the reason they are chunkin belts. do you have any pics of the brace?
Old Oct 25, 2004 | 03:36 PM
Heres the brace. Before the brace, I could push on the blower and flex the bracket about 30 thousandths. After the brace, it flexes about 5 thousandths. (checked at the supercharger pulley with a micrometer.)
Old Oct 25, 2004 | 03:42 PM
2toneblown's Avatar
yea thats pretty much the same thing we had in mind also
Old Oct 25, 2004 | 03:48 PM
I think if you machined the brackets out of a good grade of steel, and put a brace like that on it, you'd have a pretty solid setup for a F1.
Sorry for highjacking. 1BAD, Have you thought about a larger crank pulley so you could go with a larger than stock supercharger pulley and still get 9 psi?
Old Oct 26, 2004 | 04:32 AM
Is the larger crank pulley the underdrive pulley? No, I haven't thought of that. If the underdrive pulley turns the accessories slower, it would turn the supercharger slower to.
Old Oct 26, 2004 | 07:43 AM
retsell's Avatar
No, an underdrive pulley is smaller. He is talking a larger crank pulley, but it will turn everything faster, including the alternator, and power steering, a/c.
