6.2L 6.0L HO Engine swaps
Old Feb 26, 2013 | 06:34 AM
  #21
ou812sm's Avatar
Getting a 6.2 or 6.0 with l92 headw is doable without to much trouble but it will cost more and be more involved
Old Feb 26, 2013 | 10:22 AM
  #22
Camin00's Avatar
Originally Posted by ou812sm
Get a lq4 or lq9 the difference is only 20 horse and about 15 pound of torque get a good small cam that will make torque ,long tube header , tbss intake, ls7 throttle body with a x-link, and a good stall around 3000 to3200 stall and should have fun with a decent setup tranny will need work eventually but til then have fun
Exactly
what is considered a small tq cam for 6.0L for him?
212/218 114?
216/220 114?
Old Feb 26, 2013 | 05:59 PM
  #23
ou812sm's Avatar
I had comp cam lsr cam 219/227 .607/.614 on a lsa 114 it had a ton of power all over it's not the smallest but worked with what I had
Old Feb 26, 2013 | 06:54 PM
  #24
Camin00's Avatar
Did you run that cam with the stock stall?? if so how was it?
Old Feb 26, 2013 | 07:47 PM
  #25
ou812sm's Avatar
No I had multi disc 3000 stall from circle d
Old Feb 27, 2013 | 06:40 PM
  #26
lt1 sport's Avatar
L92 would be more money and time then you would probably want to spend, 58x, VVT, etc. First thing I'd do is throw that hand held away and get a real tune. My L33 GMC i had dropped off over a full second off my 1/4 time by longtubes/ORY, TBSS intake, and a perfect street tune done by me. You could always try that and if it's not enough all the parts will transfer over to a bigger engine, as long as you don't swap to rectangular port heads. Also remember your 35s are going to kill your bottom end and towing. If you still need more, a cam swap and a yank truck thruster converter would make a world of difference.
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
oharajo
Jul 18, 2015 09:24 PM
Mark_k
Jul 9, 2015 12:37 AM
Nimoryan
Jul 5, 2015 03:50 PM
