6.0 heads on 5.3
Old May 2, 2006 | 08:45 PM
Prochrgd5.3's Avatar
Default 6.0 heads on 5.3
I am fixing to buy a set of assembled patriot 6.0 heads for my 5.3. I have a procharger p1sc and the rest of the motor is stock. I know this will lower the compression which is what I want in order to run more boost. Does anyone know how low the compression is with these heads. I hope it will drop it to about 8.5. Any help will be much appreciated.
Old May 2, 2006 | 08:49 PM
ktmrider's Avatar
That is about right for the CR drop, maybe even a few tenths lower.
There is a sticky somewhere on this site that has all the info you could need on the GenIII heads and interchange, else for sure over on LS1Tech.com ( look in the Internal Engine areas ).
Old May 2, 2006 | 08:53 PM
Quik's Avatar
5 year bitches!
stock i belive is 9.5 with i believe is a 62cc head. a 317 is a 72cc head so it should drop it ot about what you stated
Old May 3, 2006 | 03:02 PM
Yelo's Avatar
6.0 heads on a 5.3 is going to cause valve shrouding due to the larger valves in the 6.0 heads....I'm not sure it'll be a BAD problem but you will end up with lower max flow potential
Old May 3, 2006 | 04:46 PM
FlaBouy's Avatar
I concur with Yellow. BTW stock heads on my Av were 61.15 cc @9.5. The new Stage 2 Patriots have a 63 cc with 2.02/1.57 Ferreas...They net me 500rwhp with the Vortech. My heads flow benched 295 @ .600. Shrouding was a consideration when I went to these heads. Truck is a beast....
Old May 3, 2006 | 09:06 PM
Chevy_Truck_Man's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
Can't remember where I found this...
Old May 3, 2006 | 11:04 PM
Richard@WCCH's Avatar
FormerVendor
Your going to need to run a 6.0l head gasket with the 6.0l head. There's a difference in gasket bore volume that you shouldn't forget to account for. It should account for almost 2cc of volume.
Good luck,
Richard
Old May 4, 2006 | 09:13 AM
What size are the valves in the stock 5.3 heads. The valves in the patriot stage 2 heads are 2.02 int and 1.57 exh.
Old May 4, 2006 | 11:11 AM
FormerVendor
Stock valve sizes for the 4.8l and 5.3l heads are 1.890"/1.550".
Richard
Old May 4, 2006 | 11:18 AM
What if I get my 5.3 block bored to a 3.905 bore. With the bore being bigger that should help out with the valve shrouding problem.
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
