6.0 build for blower
Old May 22, 2019 | 12:04 PM
  #31
03sierraslt's Avatar
Pump should be but the injectors IDK. Are you running a return system? And at what pressure?
Old May 22, 2019 | 08:03 PM
  #32
_zebra's Avatar
makes children cry
i've been running Siemens 60s (which i believe are ~72# @ 58psi) on mine for 8yrs with the stock corvette fuel system + boost-a-pump, and they didn't max out until mid-600s whp...
then we swapped the pump & BAP to a single 450 that overwhelmed the stock FPR & made about 78psi... so then i had to do a custom FPR & return line. all's good now.
regarding my extensive head work - i only did that because i'm still stock bottom, aluminum everything, and trying to reduce boost (restriction/heat) as much as possible to help longevity.
as for your pulley combo, i'm calculating about 12.5psi dropping to ~11 by 6000rpm (big engine, small blower).
Old May 22, 2019 | 09:04 PM
  #33
dantheman1540's Avatar
Yes I'm running return with an automotive FPR at 58psi.
Old May 22, 2019 | 09:07 PM
  #34
I forgot about Atomics boost calculator spread sheet. I'll run that when I get home. I'm in the same boat with stock gen 4 rotating assembly trying to keep temps down. Might end up ordering some ID injectors.
Old May 22, 2019 | 09:30 PM
  #35
_zebra's Avatar
makes children cry
that & i ain't never heard tell of the cam i got (designed for 6.2) being used in anything smaller than a 6.0
Old May 22, 2019 | 10:09 PM
  #36
1FastBrick's Avatar
Custm2500's Rude Friend
I realize pictures can be deceiving. I hope you pulled the old barbell out and cleaned all the oil passages prior to assembly. I also hope you installed a new one as well as the plug in the front.
Old May 22, 2019 | 11:10 PM
  #37
Thank you for the help!
I actually have not done either of those things myself. This is the first I've heard of it. I'm hoping the machine shop did since he hot tanked everything for me. I will have to check that out tomorrow.
Old May 22, 2019 | 11:16 PM
  #38
1FastBrick's Avatar
They usually miss that barbell and installing a new plug in the front is the end user/ assemblers responsibility.
Same with cleaning the oil gallery passages. It's the responsibility of the end user/ assembler.
I have that book and it's been a long time since I read it. I am not sure if they cover that topic.
Old May 23, 2019 | 10:39 AM
  #39
I also may have missed it I didn't go over the machining chapter as much as I did assembly.
What is the recommended cleaning process for the oil galleys?
Old May 24, 2019 | 02:17 AM
  #40
1FastBrick's Avatar
A set of brushes, warm soapy water, and some compressed air. I usually follow up with WD40 Immediately after or the block with flash rust.
https://www.lsenginediy.com/ls-engin...aration-guide/
