5.3 stroker
Old Apr 17, 2005 | 09:40 AM
10 Second Club
Default 5.3 stroker
hi to all
dose any one do a stroker kit for the 5.3 ????????
thanks
Old Apr 17, 2005 | 09:59 AM
tdrumm's Avatar
You can bore it out to stock LS1 bore and then throw in a 4" stroke crank and you'll get an iron block 382. Someone here did it. Just a 4" stroke with a stock 5.3 bore yeilds 366 I think, which is barely larger than a stock 6.0, plus I don't know if anyone makes stroker pistons for 5.3s.
Old Apr 17, 2005 | 11:48 AM
10 Second Club
thanks
but do thye also have low copmretion pistons for it with the stroker
thanks
Old Apr 17, 2005 | 12:50 PM
vanillagorilla's Avatar
I'm sure any of the forged piston manufacturers can make you a custom set if they don't make them already. Try Diamond pistons, or any of the sponsors to the right.----->
Old Apr 17, 2005 | 02:08 PM
8ALTNG's Avatar
I know that JE Pistions will make you any size you want. They will even make pistons for a forged 4.8L
Old Apr 17, 2005 | 03:19 PM
ktmrider's Avatar
I did it but bored out the block to 3.905" ( from 3.78" ). You can get the pistons custom made but the blocks will take the bigger bore without any issue and open up lots more parts options. Most folks are gonna tell you to go with the 6.0L motor and stroke it to 402 ci. SDPC makes a short block for a very decent cost, not much more than what you might pay doing the work on the 5.3/4. motors.
BTW the bore size is the exact same on the 4.8 and 5.3L, only difference is stroke. Keep that in mind if looking for donor motors.
Old Apr 17, 2005 | 07:22 PM
P.O.R.N.'s Avatar
Lunetti makes low compretion pistons, stroker kit and everyy thing now for a ls1 style motor. I know you can bore it over to make it a 350 with the stock crank, if interested i could look up what the size was.
Old Apr 18, 2005 | 09:05 AM
10 Second Club
thanks it would be a lot of help
please help me out
cos i am planning for the Livernois Motorsports turbo kit but with about 1Bar
of boost so i am looking at about 8.0/1 copretion with some good flowng heads like the ones by AFR.
mikeyjm1
17
Oct 29, 2015 11:04 PM
jtphelps289
Sep 11, 2015 06:37 PM
97gmc
22
Sep 8, 2015 10:56 PM
custm2500
Sep 8, 2015 05:53 PM
screaminian47
Sep 7, 2015 08:20 PM
