4l60e servo's and kit at 80k?
I have 80,000 on my tranny as of today. Its time to change the tranny fluid and filter. While im under there would it be wise to go ahead and do the covette servo and OD servo and shift kit.... or should I leave it stock to prolong its life. I allready run a tranny cooler (well its stock w/ the z71 towing package). I understand that the trans-kit will reduce heat and is supposed to prolong the tranny life, but what worries me is it seems like trannies like to fail right after a fluid change due to the new fluid breaking up all the junk that has accumulated. I dont want to up the fluid pressure and cause every little bit of clutch dust and dirt to instantly break free and really screw my tranny. I might have got some bad information and be all worried over nothing, but I dont want to do anything that is going to cause me to park the truck for awhile while a figure out how to talk the wife into a 4l80e swap. Also, is the transgo HD kit a hard install needing special tools, or is it a pretty strait forward install. One more thing, I hear you dont get gaskets with the transgo kit, is this true?
Trans service and a vette servo and you should be good to go.I would pass on the OD servo.When does it have a huge load when in OD? Probably never.transgo gives you a shitty cork pan gasket and VB gaskets w/HD kit.
I got a gasket with mine
the seperator plate gasket
I think thats all you need
the transgo kit isnt that bad just keep everything clean
and take your time
the dude in the vid used fluid to hold the gasket on
I used white lithium grease
worked alot better
and take your time
worked alot better
Originally Posted by gamedawgx53
I would do it
if you dont have a stall
Id drill everything besides the 1-2 .093
leave the 1-2 alone
no washers in servo and no spacers in accumulator
aluminum accumulators also
leave the 1-2 alone
lycominghunter
Aug 15, 2015 12:26 PM
SleeperGMC
Jul 29, 2015 10:22 AM
