6.0 Pushrod Talk!
Hey guys I need to know if stock pushrods will be ok for my application. I have a 6.0 with a XR275HR Comp cam and 26918 Comp springs. I'm running stock heads with a 3 angle valve job and milled .40.
If I need pushrods what length?
Thanks,
Rob
Thanks,
Rob
Originally Posted by rob3379
I think 6600 or 6800 not sure. I really need to know then if the stock length will work since I milled the heads 40.
.566/.568 lift...
1.7 rocker?
stock replacement springs
Head milled .40...
I wouldnt buy them intill I measured.... you might not need them on a hydrolic setup.. Id guess a 7.35 but that is a guess.. Im probably wrong
7.4" is stock on a LS1 3rd Gen. BTW
1.7 rocker?
Head milled .40...
Originally Posted by 02sierraz71_5.3
only way to be shore is to by a pushrod length checker, they are cheap and worth the money, I'll milled my heads .050 and am using stock length rods on a 5.3, was using .050 shorter and the valvetrain was super noisy so went back to stock length and havent had a problem, if i did it over again i would invest in a checker
legerwn
56
Nov 15, 2015 10:21 PM
jtphelps289
Sep 29, 2015 12:00 PM
