422
Old Oct 17, 2003 | 04:43 PM
Smoky02's Avatar
Default 422
What would it take for me to build a 422 for my truck(what all components would I need and would I have to do any kind of conversions??)
Old Oct 17, 2003 | 05:02 PM
MNC5's Avatar
Default Re: 422
It should bolt right up. You'll be missing a bolt for the alternater if you use a LS1 or LS6 block from a car.
I've got a complete 422 if your interested. It should make over 600FWHP N/A and will be going on the dyno in a week or so.
Old Oct 17, 2003 | 06:32 PM
Smoky02's Avatar
Default Re: 422
what's the price tag?? and I can use all of my accessories or do I need to change it over??
Old Oct 17, 2003 | 09:24 PM
silent1's Avatar
Default Re: 422
Be warned, you're looking to spend well over $12,000.
Old Oct 18, 2003 | 08:26 AM
Smoky02's Avatar
Default Re: 422
Damn, are you serious?? Is this motor gonna do me favors at night after I get driving it...j/k what's the price 427??
Old Oct 18, 2003 | 10:55 AM
silent1's Avatar
Default Re: 422
If you were to buy a 422 longblock from one of the sponsors you're looking at $11,000+ depending on alluminum or iron block. When you start adding recomended parts(head studs, mian studs, custom pistons, rockers, etc.) you're looking at an extra $1,000+ or so. Let's say you can swing that OK, now you need a drivetrain that can take it. I'm running the FLP Level IV 4L65E and once I start spraying, this trans isn't going to hold it. This trans was roughly $2,500. You really need to sit down and add up EVERYTHING that's going to be needed and then decide if you can comfortably get it done. Don't know if you're married or have kids but, this is one expense that can't be explaind as a necessity no matter how long you argue about it. Other things that need to be added to this equation is tires, brakes, and gas. You'll be going through these things at a FAST pace. Not trying to discourage you, just trying to prepare you. Good luck.
Old Oct 18, 2003 | 04:13 PM
Smoky02's Avatar
Default Re: 422
Well I was planning on building a 408, I know usually bigger is better, so I figured I would ask...I just wanted to know what actual parts I would need to build it
Old Oct 18, 2003 | 06:35 PM
BigTex's Avatar
Default Re: 422
Price of a 422 and a 408 should be roughly the same. The price of a 4" crank and a 4.125" crank are just about the same. Custom rods and pistons should cost the same for either setup. The only reason to get a 408 is to use the kit from Lunati that has the 4" crank.
Old Oct 18, 2003 | 08:40 PM
MNC5's Avatar
Default Re: 422
Drop me an email if your serious,
budhayes3
Jun 30, 2011 11:39 AM
69ss
Feb 17, 2009 08:34 PM
RED2K
Oct 15, 2004 06:52 AM
