4.8 liter NOS question
Old Jan 23, 2003 | 11:06 AM
Kevin Winstead's Avatar
FormerVendor
Default 4.8 liter NOS question
I've got a coworker that has a '02 truck with the 4.8 liter engine. He bought a sneaky pete NOS kit yesterday for dirt cheap. We were thinking about putting the kit on it, but he wants to make sure that the tuning is rich enough from the factory, because it is a dry kit. Has anyone dyno'd their 4.8L truck with the factory programming? How rich was the factory tuning? How much timing does it have at WOT with the factory tuning?
TIA,
Kevin Winstead
Old Jan 23, 2003 | 11:19 AM
BigTex's Avatar
Default Re: 4.8 liter NOS question
Typically, the tuning from the factory is rich. If he has done any other mods like intake, headers,GMAF, exhaust, hypertech, etc... it may have leaned it out some. There are several guys running dry nirtous kits with no problem on these motors. Do go too extreme with the shot or your injectors won;t keep up. I think a 100 shot is safe for fuel, other run even larger.
Timing is low from the factory, and fuel is rich. No problem. If he has hypertechs "power tuning" installed, that will raise timing and lower some areas of wide open fuel. Thats why you shouldn't run hypertechs tuning and nitrous at the same time. The hypertech settings for shifting, rpm limiter, etc... are fine with nitrous.
Old Jan 23, 2003 | 01:29 PM
CashDudeHomie's Avatar
With a dry kit, shouldn't you spray directly into the maf sensor?
Old Jan 23, 2003 | 01:34 PM
BigTex's Avatar
Yes, before the MAF.
Old Jan 23, 2003 | 01:55 PM
GREGGO's Avatar
Spray at least 6" in front of the MAF so it will get a better pattern.
Old Jan 23, 2003 | 01:59 PM
GREGGO's Avatar
I agree with what Bigtex said about taking out the HPPIII setting on a dry shot system. I think that was a contributing factor in my "piston failure" <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Greg
Old Jan 23, 2003 | 06:21 PM
Texas Terminator's Avatar
11 Second Club
i was running a 4.8 with 8-10# and still had to lean it out a bit and still was a little rich. wouldn't worry too much about it, put it on a monitor sometime soon or at least do regular plug readings.
Old Jan 24, 2003 | 01:09 PM
FormerVendor
Thanks for the help guys!
Kevin
dry_kill
11
Aug 28, 2015 09:53 PM
89sierra
Aug 19, 2015 07:13 PM
08lambochevy
Aug 7, 2015 11:42 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
