4.8 liter mods-will they work on a 6.0
Old Jan 23, 2003 | 08:27 PM
jr4x4's Avatar
Default 4.8 liter mods-will they work on a 6.0
I HAVE FOUND A 6.0 AND WAS WOUNDERING IF THE MODS THAT I HAVE DONE TO MY 4.8 WILL WORK ON THE 6.0? THE 6.0 IS MISSING THE INTAKE, WILL MY 4.8 WORK?
2001 GMC SHORTBED STANDARD CAB/JBA HEADERS/ASP PULLEYS/GRAN MAF/K&N GEN 2/HYPERTECH PROGRAMER/BBK THROTTLE BODY/6" FABTECH LIFT/33" SUPER SWAMPERS/ 4:10 GEARS/POLISHED ALUM EVERYWERE/ALPINE STEREO/500:1 AND 300:4 JL AMPS/
6 1/2 FOCAL SPEAKERS WITH TWEETERS/4X6 ECLIPES/AND 6 8" JL SUBS BEHIND THE SEAT
Old Jan 23, 2003 | 09:00 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: 4.8 liter mods-will they work on a 6.0
5.7L Aluminum LS1
5.7L Aluminum LS6
4.8L truck
5.3L truck
6.0L truck
All of these engines are completely swappable. All their heads bolt onto eachother, all of their intakes bolt onto eachother, and all of the external engine bolt-on modifications are swappable too.
I may try and find a stock LS1 (aluminum) to stick in my GMC. About 30 more hp and 80 lbs lighter.
-Tony
Old Jan 24, 2003 | 06:34 AM
GREGGO's Avatar
Couple of quick notes to that:
Yes the intakes are swappable, but the LS1 and LS6 intakes are much lower and the idler pulley on the truck will interfear with the T/B depending on your air intake setup. Also, the alternator bracket on the trucks will not line up on one bolt on the LS1/LS6 blocks. But those are relativly easy fixes. One more thing, the LS1/LS6 pcm's will have different connections. You will be beter off reprogramming your truck PCM.
Greg
Old Jan 24, 2003 | 01:16 PM
GTO. MIKE's Avatar
5.7L Aluminum LS1
5.7L Aluminum LS6
4.8L truck
5.3L truck
6.0L truck
so if you had a 99 5.3 which head would you pick from all the choices above
Oobray
Jun 13, 2022 03:38 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Castro45
24
Jul 31, 2015 07:13 PM
Jake75
Jul 22, 2015 09:20 PM
Suburban2500
Jul 19, 2015 04:50 PM
