4.8 226/226 cam
Old Apr 1, 2011 | 03:16 AM
MON_06's Avatar
Default 4.8 226/226 cam
Im looking in to this custom grind cam for my truck its a 4.8 i wont lots of power from the cam i go with and yes im gonna slap on pushrods and v/springs and im even thinking of slaping on the ls7 lifters and ls2 timing chain..now the cam is a 226/.585 226/.585 lsa 110 i want a sick idle but idk about the intake centerline? Help with that...and what do u guys think about that cam yes/no is there a better one out there?
Old Apr 1, 2011 | 07:24 AM
charcoal03silvy's Avatar
That's a lot of duration or a 4.8....
Old Apr 1, 2011 | 07:30 AM
dmelvin's Avatar
It is... you're going to want at least a 3000-3200 stall with that on the 4.8, or else you're going to be sitting at a stop sign, hit the gas, and it's going to fall flat on its face.
Old Apr 1, 2011 | 07:52 AM
Nuclear Endless's Avatar
That cam would better suit an ls1 or 5.3, bit big for the 4.8
If you're wanting straight up more power just get a 6.0 in this case...
If you have to stick with the 4.8, the tsp220 is about as big as it should get, and the 212/218 comp cams are proven performers in the 4.8
Old Apr 1, 2011 | 09:29 AM
iamkeniff's Avatar
that cam would need a 4000+ converter, and 4:30+ gears to do anything. that cam is wayy to big like everyone else said. the 110-112 will sound about the same.
if you want a 112....then go get someone to cut you a custom cam based upon the 212/218 but on a 111-112 imo.
Old Apr 1, 2011 | 10:31 AM
05gmcsierra's Avatar
Too big! 220 would be max duration on a 3200much atleast. That 4.8 needs a 3600 to make up for the lack of torque.
Old Apr 1, 2011 | 10:48 AM
I agree totally, and with those gears and converter it wouldn't be to much fun to drive especially daily.
I would like to try my cam in a 112 lsa. It would be great for a 4.8L
Old Apr 1, 2011 | 11:28 AM
iamkeniff's Avatar
i wonder if Geoff Skinner @ EPS can make a cam thatll produce power just like the 212/218 but better. if i had a use for a smaller cam i would talk to him about a cam in that duration
Old Apr 1, 2011 | 03:22 PM
MON_06's Avatar
Well im gonna go with a 32stall and 410 so ill push it...but it is my dd is it gonna suck wen im driving
Old Apr 1, 2011 | 05:52 PM
its not really going to make it much faster if you can't get up and going...... Look smaller
