4.8 226/226 cam
Old May 13, 2011 | 10:14 PM
  #21
Rhino79's Avatar
9 Second Club
That cam will work with a 4000 verter and at least 4.10's. Be prepared to spin it to 7k+ for be results.
Old May 14, 2011 | 03:58 AM
  #22
stock48's Avatar
9 Second Truck Club
Isky 215/215, 108lsa
Old May 14, 2011 | 04:43 AM
  #23
slowlsx's Avatar
Be prepared to be dissapointed. Spinning your motor 7+k just for the cam to work is a stupid idea when you can achieve the same results with a smaller idea. First of how is this a "custom cam" who would spec that cam for a 4.8?
Old May 14, 2011 | 04:10 PM
  #24
Rhino79's Avatar
9 Second Club
Why is spinning a 4.8 to 7k stupid? Upper rpms is where they make power, if the rest of the setup is right, it will run good. A 215 or 220 is still gonna be a turd down low in a 4.8. I have put a 226 226 in a 5.3 and power peaked around 6400 or so, sure the 4.8 will peak higher, but with the right combo it would run great. The 5.3 engine I istalled it in ran 8.30's 1/8 mile with just a tt3000 and 4 10's. It ran 1.8 sixties and mph was great.
Old May 14, 2011 | 07:21 PM
  #25
BlackGMC's Avatar
Resident Retard
I had a 214/220 @ 108 in my 4.8 and it ran a 13.2-4 i dont remeber exactly but i had a 3600ish tc and prc heads. I shifted at 7k at the track
Old May 18, 2011 | 06:20 AM
  #26
slowlsx's Avatar
i just dont think 6200 vs 7000+ makes a big difference maybe 10hp? i installed a 220 camshaft in a 5.3 with a 250$ tci converter and it ran low 8.20's on motor shifting right at 6400 (tried high RPM's but it didnt do much at all). 220/220 vs 226/226 is alot more cam and it seems run almost identical?
that cam might work but there is obviously better options. as you can see above me 214/220 and he ran 13.2's so the OP should run 13.2's cause he wont have pRC's but the cam should make up for it right?
also i would trust stock48's judgment, afterall he is only running 9.60's at 5000+ elevation with stock heads and intake manifold. not that impressive at all
Old May 18, 2011 | 07:36 AM
  #27
Lil brother PI's Avatar
to big was the same thing they said about the cam a friend used o nhis 5.3 i think it was a 232/.605 236/.612 i think not sure and then there the one they used on my truck 236 236 and still on a 5.3 so i think u should be okay with at least a 3600 stall at least
Old May 18, 2011 | 09:55 AM
  #28
Rhino79's Avatar
9 Second Club
A 4.8 needs to spin high, its a short stroke, its the nature of the beast. It was the same with sbc 327's vs 350's. 3 years ago people would call you crazy for running more than a 224 in a 5.3. Now take a look at how many people have picked up et and mph with more cam. It just depends on where u want to make your power.
Dan Neumann
11
Aug 7, 2022 09:06 AM
JordanH
Aug 8, 2015 07:59 PM
Blackrat48
Aug 4, 2015 09:52 AM
Suburban2500
Jul 19, 2015 04:50 PM
06 4.8
Jul 15, 2015 07:17 PM
