3.42 gears, better for the 1/4??
Old Apr 24, 2003 | 01:07 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: 3.42 gears, better for the 1/4??
The speed your running in the quarter kinda makes it hard to maximize your trap rpm in 2nd or 3rd gear with current tire choices and rpm limits.
If you run a 28*10*16 slick with 3.42 gears you'd have to lock the converter at the end of the track and would still be turning over 6000rpm.
If you stay with your street tires you could hold second without locking the converter but, you don't hook on those and if you ever wanted to go faster you wouldn't be optimized anymore.
I'm thinking you should just go with a dedicated sticky tire at the track and maybe even step up to a 4.10+ gear. I think that setup would love a 100 or so shot of N20. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I think you should get a little bigger stall converter also if you go to a sticky tire. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Stall for the 60' and gear for finish line rpm.
John
Old Apr 24, 2003 | 01:49 PM
Buy a set of Drag TAs 255/50/16 do a good burnout and flash the convertor at the starting line.That will do wonders for your 60ft times and the 26" diameter will eliminate the flat spot at the 2nd to 3rd shift.You will also see a low 14 sec ET.
Old Apr 24, 2003 | 02:11 PM
CashDudeHomie's Avatar
With my 4.10s I did not lose any mph in the quarter but I gained about 4 tenths.
Old Apr 24, 2003 | 09:29 PM
The 3.42 gear does shift out of second past the 1/4 mile or about 95mph and you only are down in your revs twice,but if they don't catch me by 85 mph it's adios to 128.I like my 4.10 & auburn pro.Jim
Old Apr 25, 2003 | 12:00 AM
Default 3.42 gears, better for the 1/4??
Are 3.42 gears better for the quarter than my 3.73's. I've seen a lot of posts where truck with 3.42's run pretty quick times because they can hold 2nd gear through the 1/4 mile. There is no way I can hold 2nd with my 3.73's, even when I max out the shifts with my HPP, the truck shifts into 3rd long before I reach the finish. With tire spin starting to be a problem, would it be better to gear up to 3.42's? I can't stall fully with the Yank because of tire spin with my 3.73's, I still have to milk it off the line. Would 3.42's allow me to stall higher and get less tire spin or would that actually be detrimental to performance?
Jim
Old Apr 25, 2003 | 12:08 AM
Jim you really need sticky tires if your spinning. Sure you don't get alot of tirespin with 3.42's but...it really hits that dead lowend spot our motors have(maybe a little different for you since you have a convertor) and won't 60 foot all that great. I would really like to get steeper gearing(3.73, 4.10) myself.
Old Apr 25, 2003 | 12:11 AM
XLR8NSS's Avatar
Adkoonerstrator
What size tires do you run at the track?
I still think it would be better to hold 2nd to the end of the quarter if the overall gear ratio allows it.
If the overall ratio doesn't allow for it within the rpm limit then get a lower gear and stickier tires.
John
<small>[ April 24, 2003, 12:13 PM: Message edited by: XLR8NSS ]</small>
Old Apr 25, 2003 | 12:22 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">What size tires do you run at the track?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have the stock 255/70R16 tire size, the tires are Continentals. I know they're not a REAL good tire but the sales guy said they were a good replacement tire for the stock Generals I had. I didn't tell him I needed a super sticky tire to hook up at the track. Maybe I should get a couple of used rims and buy two good tires or ET's just to run at the track.
Jim
Old Apr 25, 2003 | 12:34 AM
MacADaYear's Avatar
Maybe its differnt for you because of your mods but...
Me and my hommie have basically the same truck with the same mods, I have 3.42, he has 3.73's
When we were racing he would alwayz get a little jump on me and I would come back once he shifted into 3nd and I was still pulling 2nd... but I think thats because he didnt have his shift points up all the way.
I want some 4.10's
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
1bad2k
Sep 7, 2015 09:26 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
fcompean
Jul 15, 2015 09:55 PM
