BUMP STOP GRIND. NEED INFO ON
Old Apr 20, 2003 | 08:49 PM
one03sierra's Avatar
Formerly one92rs
Default BUMP STOP GRIND. NEED INFO ON
NEED TO FIND OUT INFORMATION ON HOW TO DO THE BUMP STOP GRIND. I BELIEVE I HEARD THERE WERE CERTAIN VOLTAGE READINGS I NEED AND SOME HOW TO. THANKS <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Apr 20, 2003 | 08:52 PM
F8L Z71's Avatar
Default Re: BUMP STOP GRIND. NEED INFO ON
This will tell you everything you need to know. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://www.installuniversity.com/ins..._bump_stop.htm
Old Apr 20, 2003 | 08:55 PM
F8L Z71's Avatar
Hmm, they dont talk about voltages in that one....
<img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
I am pretty sure you want the total voltage @ WOT to show no more than 4.68 on the volt meter. Esentially I left the meter on and would grind a lil then read, grind a lil then read, etc. Problem is I had to grind so damn much that I got a lil overzeleous once and ground too much <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
EDIT: Here is the voltage info you want.
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=002229
<small>[ April 20, 2003, 09:28 PM: Message edited by: F8LPONY ]</small>
Old Apr 21, 2003 | 08:25 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 02denali:
<strong> NEED TO FIND OUT INFORMATION ON HOW TO DO THE BUMP STOP GRIND. I BELIEVE I HEARD THERE WERE CERTAIN VOLTAGE READINGS I NEED AND SOME HOW TO. THANKS <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you have an '02 Denali like your username suggests, then you have an electronic throttle body, which doesn't have a bump stop.
Old Apr 21, 2003 | 09:27 AM
eallanboggs's Avatar
Helm manual says the DTC is set at 4.65 VDC so you stop at 4.64 VDC or LESS at WOT. It also says the closed throttle (Idle) value should be NEAR 0.6 VDC. I read that as meaning a few hundredths above or below that value using a good DIGITAL Fluke meter. This info has been posted enough times that you should know by now NOT to get "OVERZEALOUS" while grinding. All is not lost though. You can bend the stop tab on the cam a little to compensate. You set the idle value with the stop screw (Torx). No grinding on this area.
Old Apr 21, 2003 | 09:59 AM
Formerly one92rs
I HAVE A 2002 SILVERADO WITH A 02 DENALI FRONT CLIP
Old Apr 21, 2003 | 10:39 AM
F8L Z71's Avatar
LOL
Yeah, the bit I was using wasnt taking off much amterial so I swear I checked and ground like 20 times or more and the one time I broke sequence BAM 4.71v. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
So far I have not set an SES light but will bring the voltage back down just to be safe <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 21, 2003 | 10:48 AM
Neil 6.0's Avatar
<strong> I HAVE A 2002 SILVERADO WITH A 02 DENALI FRONT CLIP </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Got any pics?
Old Apr 21, 2003 | 01:43 PM
Formerly one92rs
here are some pics
<img src="http://www.mychevytruck.com/gallery/02denali/84209.jpg" alt=" - " />
Old Apr 21, 2003 | 02:24 PM
Neil 6.0's Avatar
<img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> That looks pretty slick! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
