212/218 .558 .563 on 115 is IN!!!
Old Apr 11, 2006 | 02:50 PM
  #21
Little 5.3 Wulf Truck's Avatar
Do you have the exact part number for the cam? What else did you upgrade internally to the motor to support the new high lift cam? Thanks. Matt
Old Apr 11, 2006 | 03:30 PM
  #22
FarmerBeau's Avatar
Sexy Party Mod
We installed Comp #26918 Valvesprings, 7.400" Hardened (chromolly) Pushrods, and the camshaft was Comp XR65HR PN# 54-424-11.
You can look at the added specs here at http://www.compcams.com/Technical/Cu...ML/200-203.asp
Old Apr 11, 2006 | 03:41 PM
  #23
Coban's Avatar
I thought I had posted that on the first page.
Old Apr 11, 2006 | 03:54 PM
  #24
Thanks for the info! Are the pushrods from comp also? That cam sound's excellent!
Old Apr 11, 2006 | 04:28 PM
  #25
Seeing Red Again's Avatar
Sleeper trucks kick ***!
Old Apr 13, 2006 | 08:03 AM
  #26
unklej's Avatar
Let us know your 1/4 times with this combo, I may install this cam in my RCSB.
Jeff
Old Apr 13, 2006 | 12:58 PM
  #27
dirt track racer 81's Avatar
what kinda numbers would this cam put out being properly tuned?
Old Apr 13, 2006 | 08:44 PM
  #28
ap2002's Avatar
Jeff
tiburon had that same cam in a RCSB 5.3 and he ran a 13.0 ----
by the way it was the 212/218 with the low lift....
Old Apr 14, 2006 | 04:41 PM
  #29
02RedHawk's Avatar
Is it a 115 LSA with a 115 ICL, or did you have any advance ground into it?
Old Apr 16, 2006 | 11:22 AM
  #30
agreif's Avatar
Pretty much followed the Ls1howto article. Did you use the magnet, dowell rod or just rotate and pull method for the valves?
Go5.3tt06
25
Sep 4, 2016 10:25 AM
chopperloco
Sep 28, 2015 08:40 AM
Jake75
Sep 8, 2015 08:44 AM
stylinfosho
Sep 6, 2015 01:33 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
