2007 5.3L Vin "M" Aluminum Block??
Old 11-27-2010, 02:19 AM
Deuce's Avatar
Default 2007 5.3L Vin "M" Aluminum Block??
Can seem to find any info..............anybody know??
Old 11-27-2010, 09:13 AM
Preston129's Avatar
Mine has the M code and is an aluminum block. Can you get a look at the RPO codes, or do you just have a VIN?
Old 11-27-2010, 11:17 AM
Coban's Avatar
Well, the block is made out of aluminum......
According to GM Powertrain, the only difference is the block material. In 2010 all the engines got VVT. 9.9:1 compression ratio, same as iron.
315hp/335ft-lbs on gasoline.
Old 11-27-2010, 11:08 PM
Deuce's Avatar
I was just told it is a M Vin code 2007 5.3L.........no RPO codes.
Old 11-27-2010, 11:43 PM
1Bear's Avatar
A 2007 "M" VIN Code 5.3L engine would be a LH6.
Old 11-27-2010, 11:54 PM
Where's the Beef?
viciousknid's Avatar
most people go by RPO code and not by VIN. LH6 is basically an aluminum block 5.3 with active fuel management since it's a Gen IV engine. For comparison It would be the new generation Aluminum version of the LM7 iron block. AKA LM4 for Gen III
Old 11-28-2010, 11:32 AM
Deuce's Avatar
What do I need to do to swap this engine into a 1999 GMC with a 4.8L??
Old 11-28-2010, 07:02 PM
rickjamesCC's Avatar
Well dude I have been looking at that similar swap and if it has the DOD it will have the 58x reluctor ring not the 24x you have, it will have the cam sensor in the front of the engine, will need wirring exstensions for that and for the knock sensors they are located on the side of the block not in the ey cover, oh and you would have to retap the block for you knock sensors, you would have to change the reluctor ring to the 24x on the crank, you would have to do away with the DOD that sits under the intake manifold (very noticeable) the variable timing would have to be romoved if it has it, it would just be alot of work if you are using your PCM, which I would, just get a 6.0 and call it a day!
Old 11-28-2010, 07:37 PM
Deuce's Avatar
I think I'll find a 6L.
That sounds like alot of work for a truck I want to beat up on a road course.
chopperloco
07-10-2016 10:45 PM
6.0l RST
11-23-2015 11:30 AM
mikeyjm1
17
10-29-2015 11:04 PM
USMCvet0311
09-04-2015 09:43 PM
121
07-16-2015 12:18 AM
Quick Reply: 2007 5.3L Vin "M" Aluminum Block??
