14 bolt rearend prep?
Old Nov 16, 2004 | 02:41 PM
vanillagorilla's Avatar
What kind of power are we talking here? This sounds like a serious rear-end. It will also eat up a lot of power. Just something to ponder over. Have you blown up your 10bolt? At any rate Moser, Strange and the like will make you an axle to any configuration that's possible.
Old Nov 16, 2004 | 02:45 PM
Yelo's Avatar
Originally Posted by Scream
So, what you're saying is to get a NBS 14-bolt and put the OBS 6 lug axles in them?
yup....the axles are the same for all AAM 14 bolt SF housings, I've done this swap on another truck and I'm currently thinking about doing it on the one I have so I can get a better choice of rims
Old Nov 16, 2004 | 02:56 PM
Scream's Avatar
MOOBIES Moderator
Just curious--how could one convert the front to 8-lug? I always thought a RCSB would look cool on some 8-lug wheels.
Old Nov 16, 2004 | 03:04 PM
Yelo's Avatar
You have to swap to the 3/4 ton LD/HD spindle.....they use a spindle that actually bolts the hub to it from the backside (looks like a 1/2 ton 4WD spindle but ALOT heavier-duty....the 2wd and 4wd LD/HD trucks actually use the SAME spindle), they will bolt onto the 1/2 ton control arms without issues. To swap from 8-lug to 6-lug you just reverse the process (I'll have to get 1/2 ton 4wd spindles...if I had a 2wd I'd get the 2wd spindles)
Old Nov 16, 2004 | 07:00 PM
Would they earlier axles with a 6 bolt work even though the rear end is set up for drum brakes?
Old Nov 16, 2004 | 07:33 PM
foxspy's Avatar
My 454ss came w/ 14 bolt, 9.5", 5 lug.
Old Nov 16, 2004 | 11:53 PM
Yelo's Avatar
YES...the axleshafts are the same...it's everything that bolts to the housing (and the housing itself) that is different
Old Nov 17, 2004 | 12:03 AM
Cool, I didn't know if that was the case or not.
Old Nov 22, 2004 | 09:13 AM
Mater's Avatar
how about using the hole rear (14bolt6lug)from an 88 to 98 with the drum brakes?
that way u could get 15'' wheels for the rear ,with more tire opions?
mikeyjm1
17
Oct 29, 2015 11:04 PM
Justin87gn
Sep 10, 2015 12:06 PM
600 horses
Sep 10, 2015 11:01 AM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
