14 bolt rearend prep?
Old Nov 16, 2004 | 11:21 AM
Default 14 bolt rearend prep?
I'm wanting to swap to a heavy duty rearend and thinking a used 14 bolt out of 3/4ton Tahoe or Suburban with a Eaton posi might fit the bill.Who makes 6 stud axles to fit a 14 bolt and will the brakes and ABS hardware work with my 1/2 ton Tahoe?
Old Nov 16, 2004 | 11:36 AM
hellbents10's Avatar
LS1Tech Sponsor
whoa, what are you building. I know there is a guy on here with a Tahoe that might be able to help you.
Old Nov 16, 2004 | 12:03 PM
2toneblown's Avatar
Hey Whitt, im looking to do the same set up. Please let me know how this goes for you.
Old Nov 16, 2004 | 12:19 PM
creederado's Avatar
any luck with these guys?
Non Sponsor
Old Nov 16, 2004 | 12:21 PM
STUB25's Avatar
I'm thinking Moser Axles or Something like Dutchman should be able to make them for reasonalbe price or already have them! Also depends on the number of splines
Old Nov 16, 2004 | 01:04 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I would go with a Strange 12 bolt instead of that. It's gonna eat up a lot of power. Strange can make the alxes whatever bolt pattern you want. Give them a call.
Old Nov 16, 2004 | 01:41 PM
Yelo's Avatar
The stock 14-bolt 6-stud axles will handle more power than even parish8 can throw at them !!.....I'd just get a set from a Z71 with a towing package or a 1500HD and call it good
Old Nov 16, 2004 | 01:48 PM
Scream's Avatar
MOOBIES Moderator
All the 1500 HD's I've seen have 8 lug axles.
Old Nov 16, 2004 | 02:31 PM
Yelo's Avatar
Hrm...I swear I've seen some with 6 but I could be wrong
Anywho....the the 88-98 2500's and heavy 1/2 ton Z71's (with the towing package) all had the 14-bolts with 6-lug axles too, and those are EXACTLY the same as the NBS 14-bolt axles (the axle shaft is...the housing is different)
Old Nov 16, 2004 | 02:35 PM
Scream's Avatar
MOOBIES Moderator
So, what you're saying is to get a NBS 14-bolt and put the OBS 6 lug axles in them?
