08 4.3 to 09 6.2 - swap help
Old Nov 1, 2013 | 02:05 AM
d2tropical22's Avatar
Post 08 4.3 to 09 6.2 - swap help
My truck -
08 v6 nnbs regular cab - pics will be posted soon
Now not looking to race or put massive power just yet I'm just going to get it running 1st lol
Found a 6.2 with no Trans and computer but comes with harness .
Now the questions
From my local Facebook friends and 225racetruck group ill need a 07-08 v8 harness And computer not 6.0 tho and I need a4l80 Trans to go the simple install route by not going 6-speed but if I can find a newer 6-speed or whatever I need . Well here is where I'm stuck at .
What to do lol ? Thanks !
Old Nov 13, 2013 | 11:48 PM
As my search continues .
I found a 6l80 Trans that ill be going with now I need the motor -
After research I came across a 08 tbss motor fairly cheap . Any opinions to what I'd need to get it going into my truck ? Harness ?
Old Nov 14, 2013 | 03:54 PM
Z71crawford's Avatar
225 member here! You already have a tough swap going on, id leave the stock 4l60e in it and get the ls2 running. After the 60e dumps on you then i would look at the 6l80e swap. Just my opinion. Either way it'll be a badass swap.
Old Nov 14, 2013 | 11:58 PM
I figure I'd keep my search for the 6.2 with harness and use the 6l80y buddy has .
Thing is I wonder of that's all ill need is the motor and harness and if the 6.2 harness will work for my truck or not
Old Nov 15, 2013 | 09:27 AM
Is this truck a DD? With this swap itll be down for a while if you plan on swapping this 6l80e to.
Old Nov 16, 2013 | 02:07 PM
GWEE's Avatar
In for info and pics as im planning the samething. I called the parts depot at my local Chevy dealer and it seams the V8 motor mounts are $14X.XX each.
Old Nov 19, 2013 | 01:52 AM
After research I don't think it's gonna be that hard .
Why u say it would be down ?
Old Nov 19, 2013 | 01:57 AM
And no ls2 I'm sticking with the 6.2 I had found and think I'm picking it up this weekend when he pulls it
Old Nov 19, 2013 | 05:21 AM
iamkeniff's Avatar
As ive told you...its pretty cut and dry swap by the looks. Only issue i can see is the ac stuff which can be swapped out im sure. Next will be tuning you just have to trick the ecm to having your vin.
Old Nov 19, 2013 | 03:02 PM
I say it will be down a while if your swamping motor and trans, unless you have everything you need and knock it out in a weekend. Once its in and running i think you run into the issue of tuning. It can be done but i've heard from a few different people that it takes time. Take pictures though id love to through the 6l80e in my truck.
