07 classic cam position sensor location
Old Mar 9, 2008 | 01:25 AM
mcfarlnd's Avatar
Un-Registered User
Default 07 classic cam position sensor location
where is it? front or rear? on what? the reason im asking is because i dont want any suprises when im doing my cam swap next week.
Old Mar 9, 2008 | 03:37 PM
TURBHOE's Avatar
maybe you should put this in the eng internal section.
Old Mar 9, 2008 | 08:33 PM
mcfarlnd's Avatar
Un-Registered User
thanks buddy
Old Mar 9, 2008 | 08:54 PM
built408's Avatar
Its in the rear of the engine next to the oil pressure switch..... Same spot as if there was a distributor.... You wont have any problems with the sensor when doing the cam swap..
Old Mar 9, 2008 | 09:13 PM
mcfarlnd's Avatar
Un-Registered User
have you done a cam swap on a 07 classic?
Old Mar 9, 2008 | 10:33 PM
TURBHOE's Avatar
what he is trying to figure out is when did they move the sensor to the front of the eng. and what do you do about it when you swap cams out with a cam for a regular ls1.
Old Mar 10, 2008 | 08:04 AM
mcfarlnd's Avatar
Un-Registered User
Old Mar 10, 2008 | 11:01 AM
built408's Avatar
no I haven't. But the cam sensor location hasn't changed if it's an 07' classic... Its the same Gen 3 engine.
Old Mar 10, 2008 | 11:48 AM
BLACKND's Avatar
Yeah, the 07 classics still use the Gen 3 engine so the loc hasn't changed. Its just the 07-up NNBS that have gone to the LS2 based Gen 4 where the cam sensor is located in the diff location.
At least that is my understanding.
OHsixLS3
Dec 27, 2016 09:30 AM
Denali08
Aug 9, 2015 04:34 PM
Cm_gmt800
Aug 3, 2015 09:13 PM
hartinclay
Aug 2, 2015 06:44 PM
Slammed96
Jul 27, 2015 07:22 AM
